10-12-2018, 07:27 PM   #1
Used 50-135 F/2.8 SMC DA * ed if sdm from 2008
As the title suggest, I found a used 50-135 F/2.8 SMC DA * ed if sdm. The guy bought it in 2008 and switched to Nikon in 2013, so it hasn't been used since. He says its still works and optically and cosmetically its in great shape. But I've read to many horror stories about the sdm failing that I'm nervous to buy it even though its selling for 200. So I was wondering, If I buy it and it does fail, am I guarenteed to be able to convert it to screw drive (I shoot with with a k50, not sure if it matters)
10-12-2018, 07:45 PM   #2
The secret is to always exercise the SDM auto focus motor every few days. I understand the problem is the lubricants used in the quick shift mechanism. If you don't use the lens then the lubricants harden to such an extent that the SDM motor can bot turn the auto focus in the lens.
And yes, it is possible to convert this lens to screw drive only. There is a regular listing in the Marketplace for this service.
$200 seems like a very good price.
Regards
Chris
10-12-2018, 08:25 PM   #3
QuoteOriginally posted by seventhdr Quote
Regards
Chris
If it hasn't been used in 5 years, but works when I purchase it it works, is it safe to assume the SDM isn't damaged as of yet?
And if I convert it its guaranteed to work?
And k-50 can use the screw drive?
Thank you so much seventhdr
---------- Post added 10-12-18 at 09:31 PM ----------
Regards
Chris
I guess my real question is, if I buy it and the motor fails, am I almost guaranteed to still have a usable lens? I really want the lens but 200 is still a bit of money for me.
Nathan
10-12-2018, 10:02 PM   #4
Sandy Hancock's Avatar
Two hundred bucks? Just buy it! Brilliant lens.
If the SDM fails, converting it to screw drive yourself is not terribly difficult, or if you'd rather leave it to @UncleVanya it won't cost you much.
10-12-2018, 11:04 PM   #5
So theres no chance the lens will be completely unusable?
10-12-2018, 11:07 PM   #6
I agree- a fantastic price for a fantastic lens! I've had mine put away for many months on end, and when I get it out it still works fine. I've also had mine since 2008. I don't leave it on a camera body, however, just stored in its cloth case, or in a belt holster case in a cabinet. From what I've read here, the conversion to screw-driven is no big deal if needed. I don't use it all the time, but it is one of my favorite lenses. Oddly, I find myself using it more after getting the KP.
10-13-2018, 05:35 AM   #7
UncleVanya's Avatar
QuoteOriginally posted by nmcleod1993 Quote
As long as it focuses manually and registers on the camera and allows aperture control it will work well. Most likely you can get it to work in screw drive mode if those two things are true. Even if you can't it is a good enough lens that $200 for manual focus wouldn't be irrational.
---------- Post added 10-13-18 at 08:36 AM ----------
Conversion to screw drive isn't terribly difficult but does require an older body.
10-13-2018, 08:46 AM   #8
Is it ok if it turns the manual ring while focusing with AF?
10-13-2018, 11:53 AM   #9
$200 is a great price. I can’t see how you can pass on it. As said if you can only focus manually it is still a great deal. I’d be willing to buy it to either resell this or sell my current copy depending on condition
10-13-2018, 04:53 PM   #10
UncleVanya's Avatar
I don't remember my manual focus ring turning by itself during af. If thats what you mean I don't think that is normal. If you mean you can freely turn the ring during af manually then that is ok and by design. It is part of how quickshift works on that lens.
10-13-2018, 08:53 PM   #11
This "secret" seems like a PITA, especially if it isn't a lens you use all the time naturally.
10-14-2018, 06:06 AM   #12
rogerstg's Avatar
QuoteOriginally posted by leekil Quote
Take it with a grain of salt since it's the result of anecdotal experiences. Well meaning, but not at all scientific. FWIW, I've done everything "wrong" according to this secret, yet my lenses work fine. I recently bought a used 50-135 for more than double the OP's deal. It's a great lens, but like any used lens, things can go wrong.
10-14-2018, 07:35 AM - 1 Like   #13
UncleVanya's Avatar
QuoteOriginally posted by rogerstg Quote
100% agree on the secret... These lenses sit on shelves in boxes and don't have freshness dates; camera stores don't take them out and wake them up. I think the symptom - failing sdm losing torque - may drive the behavior. Stiction (increased static friction) could potentially increase while a lens is stored making the startup harder for a failing motor. Sometimes the failing sdm motor might struggle to get things moving. The capacitor explanation however seems like magical thinking. For lenses without failing sdm I don't recommend this as the practice appears to me to be unnecessary.
10-14-2018, 03:29 PM   #14
Yes. You're right. It is a pain in the arse. But it's a great lens.
By exercising the lens you avoid an SDM failure due to poor engineering design by Pentax. Pentax should really have been more forward to buyers about acknowledging the problem, retrofitting failed lenses and engineering an improvement to the components used in the lenses that contributed to the problem. It's a typical Japanese thing though to not admit to your failures.
Regards
Chris
10-15-2018, 08:55 AM - 2 Likes   #15
Got the lens, no SDM failure yet. But boy is it a fun lens. Thanks all for the advice and help I really appreciate it
50-135mm 2.8 sdm, auto, chris, da, drive, f/2.8, f/2.8 smc da, focus, k-mount, lens, lubricants, motor, pentax lens, price, screw, sdm, slr lens, smc
For Sale - Sold: SMC Pentax DA*50-135 F2.8 ED [IF] SDM in Excellent condition Driline Sold Items 3 04-08-2017 07:10 PM
SMC Pentax-DA 55-300mm F4-5.8 ED vs SMC Pentax-DA* 300mm F4 ED [IF] SDM Budster48 Pentax SLR Lens Discussion 12 06-30-2013 11:00 AM
No more SDM failures? -Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Taviali Pentax SLR Lens Discussion 12 03-13-2012 10:01 AM
All times are GMT -7. The time now is 12:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
