10-14-2018, 10:50 AM   #16
ChristianRock's Avatar
This might be a dumb question but why not just take the filter off and do a test?
10-14-2018, 10:57 AM   #17
QuoteOriginally posted by ChristianRock Quote
Exactly what I intend to do, however....Has anyone found this highly rated lens to have unacceptable amount of flare?
10-14-2018, 11:05 AM - 1 Like   #18
BigMackCam's Avatar
QuoteOriginally posted by MrEarle Quote
It's not known for that, and I've been shooting with mine for several years without that problem (during which time, I can say that it generally earns its positive reputation). I mentioned my approach - with hood, without filter unless absolutely necessary. Tiffen filters are bad for flare. Next step, as you say, is to test with and without filter side by side
EDIT: In the years I've been on this forum, I don't recall anyone mentioning that they were getting significant flare from this lens, either. So you can safely assume it's not a general problem.
10-14-2018, 11:29 AM   #19
ZombieArmy's Avatar
I've shot lenses with bad fungus and coating damage and couldn't even get flare like that. Seems like a poorly made filter to me.
10-14-2018, 12:57 PM   #20
Pelto's Avatar
I have used this lens for about a year on my K-70, and itís now my absolute favorite walk around lens, super sharp, very good auto focus, always used it with a Hoya PRO1 Digital Protector filter, and i never had any flare problems like those you discovered.
10-14-2018, 01:01 PM   #21
Otis Memorial Pentaxian
I believe that question is not pertinent to your poor results. If you get similar poor results without the filter, then chances are excellent there is a problem with your lens. There are three pages of reviews on this site, many of which feature examples from conditions that should create flare, none of which is objectionable. There is also an in-depth review that does not call out any particular issues of this sort indicates poorer performance compared to market competitors, but none for simple situations such as in your examples.
10-14-2018, 01:23 PM - 1 Like   #22
Mine never has.
10-14-2018, 03:17 PM - 1 Like   #23
I do tend believe the filter at fault and I will continue without it or try a better quality filter.
10-14-2018, 05:52 PM   #24
There will usually be some degree of light loss when using a CPL filter, even when using the best that are super-multicoated against flare. They would be best used to address certain situations and for certain effects. I am with others in saying do some shooting without the filter to better evaluate the lens, and phtoptimist gives good advice in dealing with the sun in general.
10-14-2018, 05:58 PM - 1 Like   #25
If I shoot mine towards the sun or the sun is in the shot someplace, the lens will give me flare 90% of the time. This is with no filters and with a UV filter. I just live with it or keep moving till the flare is at the bottom and I can crop it out.
10-14-2018, 06:13 PM - 1 Like   #26
ramseybuckeye's Avatar
I have this lens and also a Tiffen CPL, I have not noticed any unusual amount of flare with or without the CPL, really very little flare. I have had the filter since 2012, it may be a different version. I'll have to say that years ago I bought "kenko" filter on ebay that was an obvious counterfeit or factory reject, it hugely degraded the image quality of every exposure and I thought my DA 55-300 was a dud. I learned my lesson and will only buy filters from a reputable store. Definitely try it without the filter, an easy way to rule that out. Good luck.
10-15-2018, 07:05 AM - 1 Like   #27
lsimpkins's Avatar
No, I have the lens and have not found any instances of unexpected flare. And when I do see flare, I adjust my composition to minimize it to acceptable levels. It is my most used lens.
10-15-2018, 08:57 AM - 1 Like   #28
demondata's Avatar
Have this lens and have no issues with flare. I always, always use the hood, but then I do that with all my lenses.
10-16-2018, 01:08 AM   #29
clackers's Avatar
I have this lens and it's excellent.
Don't use any filter unless you have a specific purpose and are willing to cope with its interference in certain scenarios.
I say that as a frequent CPL user, too, BTW.
amount, camera, dc flare, f2.8 ex dc, flare, lens, pentax help, photography, sigma 17-50mm f2.8, troubleshooting
Sigma 17-50mm EX f2.8 or Sigma 24-70mm EX f2.8 Skipper74 Pentax K-5 & K-5 II 18 03-07-2013 05:41 AM
Wanted - Acquired: Sigma 17-50mm f2.8 EX DC HSM -or- 24-70mm f2.8 EX DG HSM AirBoss Sold Items 8 05-20-2012 06:52 AM
For Sale - Sold: Sigma 10-20mm f/4-5.6 EX DC J and Sigma 17-70mm f/2.8-4 DC Macro runjmb Sold Items 18 07-19-2011 01:17 PM
Sigma 17-50mm F2.8 EX DC OS HSM v Tamron 17-50mm f/2.8 XR Di-II LD Aspherical [IF] lmd91343 Pentax SLR Lens Discussion 6 05-25-2011 07:04 PM
All times are GMT -7. The time now is 11:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
