Originally posted by awscreo I have indeed. But, I noticed that values are different for different distance. For example, at close distances I can use - 7 af adjustment value with good results. But same values don't work well for objects at far distances (best value for that is +3 for me).
I also tried calibrating da 50 1.8, similar results. At different distances values that work differ.
I use afs, single af point, usually in the middle (I think that's the most precise point in K-1?). I try to aim it at things that have some contrast in them, like an eye in portraits, where skin should theoretically be contrasted with a shadow inside the eye, or the pupil. I'm. Not sure what side objects work best with this af system. Maybe eye is too small with full body portraits. I have higher success rate aiming at the horizon at infinity, I guess the strong separation of sky vs horizon line makes it easier to obtain good focus.
My Tamron 90 2.8 macro is much more reliable at focusing, I haven't noticed back/front focusing, it seems to always work fine.
I too found FA a bit hit or miss.
Honestly it's probably just your high expectations in conjunction with a subpar OVF experience. I really don't use my OVF that much these days, and I have an expensive Tenpa 1.22 magnifier in place to assist with determining focus.
Here's what I have concluded;
1) OVF with AF is hit or miss at times, when I use OVF I do it for AF.C and burst shooting purposes.
2) If I have the time for a shot (such as studio/static objects or location shoots) I use the Live View, I get way more feedback if something is in focus with that. Using Face Detection
Zoom I find the very best. Monopodding can also help with that.
3) When I do use the OVF (with my Tenpa 1.22) and I'm not AF.C bursting, I quite often just use Manual Focus, I can frame things quicker and just shoot.
4) My top trick is to use Manual Focus yet also use back button focusing, and before taking the shot set the Shooting Mode to Continuous High Burst, then when you get confirmation through the OVF that focus has been obtained, start shooting, but as you're shooting slowly rotate the focus ring throughout the burst of 1-10 images or so. Somewhere in that bunch one will be a sharper image than the rest, use that frame, delete the rest. Practice this technique and you can do it with subjects not even on the AF point, just judge with your eyes. Point is, maximise the single best advantage digital cameras gave us over film, disposable shots
People don't seem to understand that OVF PDAF is a range, not a single point, this accounts for all the back focusing and what not, the system struggles at many times to find that exactly perfect sharpness point. If you have lenses with Quickshift, use it, as you take the shot burst and ever so slightly change the focus throughout the shot, this increases your chances of landing a shot that has better sharpness than the rest.
Honestly, I've lowered my expectations of AF, I now think of it as something to get me to the ball park of where I want focus, but I now have to deploy tricks to get the sharpest shot possible (which I detailed above).
New lenses (like the DFA 50/1.4 etc) may make all that work unnecessary, but comes with a hefty price tag.
