Originally posted by bikehead90 I just took receipt of the swirly bokeh Helios 44-2, and this thing is strange, and I'd love some advice from those of you who've used it. I have the Pentax-brand K-mount adapter, so I'm good there, but I'm unsure how to use this thing. I regularly use my M and A-series lenses on my K7 and K3, without any difficulty (as well as my K1000), but when I put the Helios on the digital bodies, their display went crazy with the numbers. One second it'd suggest a shutter speed of X and a second later the SS is now Y. I get that you control the aperture via the front dial, but what is the dial that physically opens the aperture? While we're on the subject of aperture, just for clarification, wide open produces the swirly bokeh yeah? I have some engagement shoots and a couple of graduation shoots I'd like to use this with.
The "crazy numbers" symptom is almost certainly due to bad electrical contact between the lens and the camera body. The lens needs to be insulated where it contacts the camera so's the camera doesn't "think" there's a lens fitted. Try a lick of nail varnish or similar quick-drying (and easily cleanable) paint on the back of the lens. A single layer of thin adhesive tape may also be a temporary solution.
For the 'bokeh' effect you'll need to have the lens wide open, as recommended. Be aware that the effect is not as well pronounced on a cropped-sensor (APS-C) camera as it is on a full-frame camera, as the effect is most noticeable in the outer field of the image.
Whilst pre-set lenses may be second nature to those of us who grew up with them, they can be an acquired taste in this modern age of auto-everything. If the instructions given you by other posters don't quite make sense, try to find an illustrated guide or video on the internet. Even a scan of an original Zenit camera manual may help. Be aware, there are mechanical differences between the various models of Helios-44, so do try to find instructions that refer specifically to the 44-2.
Good luck and enjoy
I've used these lenses (on and off) since the '70's, they continue to satisfy!
