10-28-2018, 05:09 PM   #1
ZombieArmy's Avatar
How much does infinity adjustment cost on lenses?
I've got a few lenses that don't quite hit infinity that I'd really like to get fixed. I've tried many many times with these lenses in 6x live view but they never reach the target. How much does this minor repair usually cost to fulfill?
10-28-2018, 06:02 PM   #2
narual's Avatar
QuoteOriginally posted by ZombieArmy Quote
In some cases, for manual lenses, at least, you may be able to do it yourself by adjusting the set screw on the focusing ring.
As an example, there's info on doing so with the samyang 8mm fisheye in this post:
Focus On Newfoundland: MY VIEW OF THE SAMYANG 8MM f/3.5 FISHEYE LENS
10-28-2018, 07:37 PM   #3
Otis Memorial Pentaxian
I guess much would depend on whether it is a minor repair. On several of my lenses, adjustment (if even possible) requires close to a full teardown. On others, it only requires loosening a few grub screws. A question that remains is whether the helicoid pitch is sufficiently gentle to allow much adjustment at that end of the range. Most primes are set with the infinity mark at a distance about 2000x the focal length. That may be quite close for most wide-angles, but DOF, even wide-open, along with lack of mechanical precision makes it difficult to move to point further out while still providing a "stop" that will not result in backfocus for distant elements.
10-28-2018, 07:39 PM   #4
QuoteOriginally posted by narual Quote
Yes, adjustment is easy for the Samyang 8mm fisheye, but not for infinity. One calibrates the focus ring for a close distance and trusts that far distance will follow.
10-29-2018, 07:49 AM   #5
I have several vintage Takumars that just don't quite focus to infinity. I've been planning on tearing into them to see if I can adjust them. I figure worst case is to try the next notch over on thread alignment.
cost, infinity, infinity adjustment cost, k-mount, lenses, pentax lens, slr lens
All lens needs AF fine adjustment, does the camera need a global adjustment? Thanks bennyxyz Troubleshooting and Beginner Help 9 04-21-2016 12:36 PM
How much did film bodies and film-era lenses originally cost? Outis Film SLRs and Compact Film Cameras 90 12-30-2015 01:19 AM
How much BF/FF adjustment is too much? JinDesu Troubleshooting and Beginner Help 19 07-11-2012 03:06 AM
Why don't all lenses have infinity exactly on the infinity stop? peterh337 Pentax SLR Lens Discussion 19 01-15-2011 08:53 PM
How much does it cost to get into your local zoo? LeDave General Talk 30 08-06-2009 10:34 AM
All times are GMT -7. The time now is 10:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
