Originally posted by BruceBanner Ok... so if then considering dumping all screw in type filters and go with the square systems, how does it work... i mean what options do we Pentaxians have?
When it comes to square filters, Pentaxians have just as much options as anyone else. You will need a filter holder, an "adapter" to attach the filter holder to the lens, and then the filters. There are different size square filter systems available, the most common being 85mm, 100mm, and 150mm. Larger filters obviously require larger filter holders, and the price goes up accordingly.
For wide angle work, you're probably going to have to go at least to 100mm filters — and that's assuming the wide-angle glass you are using has filter rings. For a lens like the DFA 15-30, you have no choice but to go with 150mm filters, which are large and expensive ($150+, and that includes uncoated resin filters). If you bought a complete set of high-quality square filters for the DFA 15-30 along with the holder, you easily spend more money than the DFA 15-30 costs.
I use 85mm and 100mm square filters, but only for graduated neutral density filters. For everything else, I use screw-in filters. That's true even with my wide angle lenses (i.e., DA 15, DA 12-24, FA 20-35). The problem with the square filters is that many of them aren't even glass (they're optical resin) and, whether glass or resin, many of them don't seem to be multi-coated (or even single coated for that matter), and I prefer using multi-coated filters whenever possible. Generally speaking, all I really need in terms of screw-in filters is a high-quality polarizer and a nine or ten stop ND filter.
The one advantage of a square filter system is you only have to buy one set, but if you're getting 100mm or 150mm filters, that will be a bit cumbersome to carry wherever you go and to use on the lens. Screw-in filters are much more compact and preferable, IMO, for that reason alone.
