Originally posted by dipo 1 Do I set the picture up, and then push the green button and shoot away. Using the old spot I knew when I was at the right exposure because of the needle, with the K5 I'm missing something and not sure I know what or how. I take pictures now by how dark the viewfinder is not by looking at a setting. Just use to that damn needle.
OK...Here is how it is done with an M42 lens, in detail starting with M mode using the built-in meter and the green button:
- Put body in M mode
- Confirm that the meter is in center-weighted mode
- Set desired f-stop/aperture on the lens
- Frame your subject and stop down the lens manually
- Press the green button. The body will set its best notion of correct exposure.
- Open the aperture back up to focus
- Close the aperture for the exposure and press the shutter release
- Repeat the previous two steps, shooting at will, until either the subject or the light changes
Note that opening and closing the aperture is easily done with the Auto/Manual switch on the side of the lens. Now the instructions on doing stop-down metering in M mode without the green button:
- Substitute the following for step #5 above...Use the optical DOF preview switch to display an EV scale in the viewfinder and adjust aperture or shutter to place the bar where you want it on the scale.
Finally, stop-down metering in Av mode:
- Place mode dial on Av, Sv, Tv, TAv, or P (all default to Av when a lens with base contacts is not detected)
- Place the Auto/Manual switch in the Manual position and open the aperture to its widest setting
- Frame your subject and focus
- Stop down the lens until a suitable shutter speed is displayed
- Press the shutter release
- Repeat the above three steps shooting at will
There is one additional option and that is to use M mode along with an external, hand-held, light meter. Meter the light, set the aperture on the lens and the shutter on the camera. Open the aperture to focus and stop down for the exposure. Use those settings until either the light or the subject changes.
You may notice that the stop-down metered settings sometimes don't work very well. That is due to some quirks in how stop-down metering is handled by the main exposure meter. The above steps work about the same in live view, but with much more consistent results.
