Originally posted by pepperberry farm hmmm... I have the Sigma 28mm f1.8 EX DG, but not with the K-1...
it's a stupendous lens - I bought mine refurbished through Adorama a while back and ceased all LBA for that focal length for me....
Yes, my friend. I guess you are right. Unfortunately it's beyond my budget.
This kind of lenses (read: discontinued Sigma EX DG objectives in PKAF mount) are usually quite expensive on eBay/Amazon/whatelse, and come up as eBay auctions very rarely. When it happens, most of the times shipment is restricted to the same country (90% of the times it's the USA).
So finding them at a very good price is not very likely.
There is one factor that I have to keep in mind. Actually I already have some very good manual 28mm's, like the two SMC Pentax (f/3.5 and the valuable f/2 "Hollywood").
I also have a nice Sigma Mini Wide II in PKA mount and a Kino-made 2/28mm (well, two... branded Vivitar and Kiron, unfortunately both are PK, not PKA).
If I have the M42 adapter on my K-1, and I go out with screw mount lenses only - as I do quite often - I also have a choice of 3 or 4 nice M42 optics, like the Soligor C/D P 2/28mm or the Komura 2.5/28mm.
You see that I have a good number of 28mm lenses that perform well enough, if I don't need AF and I can use them at their sweet spot.
If I didn't need an AF prime, preferably of low weight/size, I would probably forget about a 28mm. I have plenty of them and the focal is also covered by a couple of very good f/2.8 zooms.
To be sincere, I really can't say I "need" it, let's say I "want" an AF prime, better if fast and not too big.
I'm still trying to find a Pentax-F/FA, it's quite good and it's easy to carry around. A pity it's usually priced above what I'm ready to pay (and above what it's worth, IMHO). Same thing applies to the 2.8/135mm AF, btw.
There is not much else to choose from. The only alternative that's cheap enough and maybe good enough is the old Sigma Aspherical AF.
It's fast but still manageable.
I haven't found anything else with my searches.
Any other suggestion is appreciated.
I'm interested in first hand impressions of the Sigma Aspherical on FF (K-1, Sony mirrorless, or even Nikon, cause for example the D810 shares the same sensor of the K-1).
If it performs well enough only at medium apertures it's definitely worth waiting for a nice deal involving the EX DG or a Pentax AF. If it performs in a satisfying way wide open I'd be happy to go for the old version and be fine with it.
EDIT:
As I've already said, I often like to go out taking pictures using only a set of M42 lenses.
While I found that many very old 35mm lenses are still very usable, especially taking care of avoiding stray light, the older 28mms are more problematic.
I like to experiment with very old lenses. Some 50/55mm are still impressive, either because of great center sharpness or because of a very particular optical signature. Recently I enjoyed a lot the Meyer Primoplan, the 8-elements Super Tak, and two old chrome nose Tomiokas. The 28mm's of the same age have been disappointing most of the times. So I have decided to stick to more modern designs for 28mm and lower.
There were a few exception. I've mentioned two in the text above.
I'm curious to know if any of you found a sixties/early seventies 28mm that performed above expectations.
