09-25-2008, 05:06 AM   #1
eccs19's Avatar
Screw Mount Question
Last time I was at the local "Hock Shop", they had a lens there, and had it listed as a "screw mount". There was no indication if it was Pentax mount or not. I guess the question is weather or not anyone other than Pentax used screw mount, and if so, how can I identify if it is Pentax mount or not?
09-25-2008, 05:14 AM   #2
the_snark's Avatar
I'm far from an expert, and I'm sure I'll be corrected in an instant if wrong, but by far the most common screw mount thread size is M42, i.e. 42mm diameter by 1mm thread pitch. This is what you want - it's the size used by Pentax and numerous other lens and camera makers. There is an older M37 standard, but that is far less common.
If you already have a screw mount adaptor (which I'm guessing you don't if you are asking this question), you could bring that and try it on the lens. Failing that, you could see if there's an old screw mount SLR in the shop, and see if the lens fits it. Another way is to measure the thread to see if it's about 42mm in diameter.
M42 info at Wikipedia: M42 lens mount
What was the lens BTW?
09-25-2008, 05:24 AM   #3
eccs19's Avatar
QuoteOriginally posted by the_snark Quote
Thanks for the info. I doubt they have a camera I can check, but it's easy enough to measure the diameter of the threads. Sorry I don't remember what make the lens was, I just know it wasn't a Pentax.
09-25-2008, 05:42 AM   #4
Moderator Emeritus
Snark is right. Always have an M42 with you. I carry one in my wallet so if i come across a gem anywhere, I can check the lens. There are T mount lenses that have a similar looking mount (although the rear element usually sticks out further) that is the same diameter but a different pitch and need a different adapter but will also work. There is also the M39 Lieca lenses that are close enough in size to be tough to spot.
So don't assume all are equal. Grab a cheapo Ebay M42 and keep it handy to check a flea market 'find'.
09-25-2008, 05:51 AM   #5
eccs19's Avatar
QuoteOriginally posted by Peter Zack Quote
You mean a cheap M42 lens, or adaptor? Not sure how you would keep a lens in your wallet.
09-25-2008, 06:13 AM   #6
Moderator Emeritus
Revised Yes the adapter.
09-25-2008, 06:33 AM   #7
Nesster's Avatar
"Is that a lens in your pocket or are you just happy to see me?"
09-25-2008, 06:46 AM   #8
konraDarnok's Avatar
It's worth noting there are two M39 variants. One is for Lieca and has a short flange to image plane distance. The other M39 has the same flange to image plane distance as M42 lenses -- these can be used on a pentax camera with an M39 to M42 to K adapter.
There's a few Russian lenes with M39 mounts that will work in this way. The Helios 40 85mm f/1.5 being the most notable example.
The Helios 40-2 is M42.
Lieca M39 would only work as a Maco Lens in that configuration -- with no infinity focus.
k-mount, pentax, pentax lens, question, screw, slr lens
Hey new here, quick question, is this K mount or M42 Screw Mount? Lulerfly Pentax SLR Lens Discussion 8 11-02-2010 11:58 PM
K-Mount to Screw Mount Adapter Ring is Stuck steve101a Pentax SLR Lens Discussion 27 03-24-2010 02:59 AM
Screw mount lens on a k10d question GatorPentax Pentax SLR Lens Discussion 8 12-03-2007 11:31 AM
For Sale - Sold: FA: Original PENTAX Screw Mount to K Mount Adapter M42 HogRider Sold Items 0 10-21-2007 02:12 PM
All times are GMT -7. The time now is 01:43 PM. | See also: NikonForums.com, part of our network of photo forums!
