As far as the pin and baffle are concerned, neither interfere with my K1's front bits inside the mount. Being new to Pentax DSLR's though, the only way I could figure out how to make the aperture stop down is to not turn the lens in all the way until the mount lock clicks.
dimensions etc
The lens weighs 460g (16oz and a smidgen), has 8 diaphragm blades, 72mm filter thread and minimum focus distance about 0.75m (just under 30") at 110mm versus 1.5m at other focal lengths. Its maximum length equals 135mm and minimum is 98mm.
performance: the good, the strange and the ugly
Here is an example of several ocotillos in the wild at 28mm and f11:
Clearly there's good news and bad news: the enter is extremely sharp and has no problem resolving all the detail the K1's sensor can handle. On the other hand, things turn soft at the top and bottom edges, and from about the left and right quarters of the image width they go from soft to goddawfully mushy. Here's a crop of the center and some of the softening towards the left quarter. The tip of the second foreground branch is almost exactly at the image's centerpoint:
And here's one of the hot messes in the corners:
The extent of the left and right-side mush varies in complex ways with focal length, aperture and focal distance, in a somewhat strange interaction that I haven't figured out yet. Although the corners never become great, subjects that are about 3-6m away, longer focal lengths and f8 seem to suffer the least. Here's a chain link fence at 5m, f8 and 110mm:
In this case the central circle of sharp and CA-free detail seems to extend just about from top to bottom and the leftmost sixth to the rightmost sixth of the image. The corners are still not great, but they're a lot less mushy than above. Note also that there's a hint of pincushion distortion, this is true across most of the zoom range and gets a little bit more noticeable at its widest end.
Here's the tallest individual ocotillo i've come across in 15+ years, shot at 70mm f8 from about 30m away. Meet Shorty:
Typical ocotillos mostly get to about 4-5m or so, but this handsome fellow (or gal?) towers to 8m. In this shot the top (which was the right side in previous examples) looks pretty much sharp all the way to the tips of the soaring canes, while the bottom 10% of the foreground (left side in previous images) is mushy but probably that's due to being in front of the leading edge of the DOF zone.
---------- Post added 11-23-18 at 05:37 PM ----------
but what about wide open?
As I was mostly hoping for a good landscape lens, I didn't play all that much yet with f2.8 at the widest end of the zoom range. What I've tried so far looked pretty sharp and contrasty in the center circle, but at 28mm you get quite strong vignetting with wide apertures, and at f2.8 the corner pockets become entirely black as if the image circle only covers 95% of full frame. At the long end, things are in many ways different: f3.8 gives the periphery of the image a swirly look while the center turns into a soft focus effect, rather like tamron's 35-105 2.8 adaptall and the early Tokina ATX 28-70 (2.6-)2.8 versions.
Here's an ocotillo flower spike as 2000 pixels wide center crop of a shot taken at 110mm and minimum focus distance in "macro" range, wide open at f3.8:
Compare that with the same subject at 110mm and f8 - with a tiny ant conveniently walking into the picture and showing off the absurdly sharp center:
Conclusions for now:
Overall this odd lens makes more sense on one of the APS-C bodies, since its center sharpness gets kinda insane at apertures greater than f5.6, while the corners and sides can turn out really really bad. Figuring out how to control or use their mushiness isn't going to be straightforward, but I'll definitely keep trying out in different settings. For the ocotillo mapping purpose however, I'm going back to my trusty 16-45 for now ... its corners aren't perfect, but at 28mm it's certainly much better behaved across a much greater part of the image than this Rikenon unicorn.
