12-07-2018, 09:35 AM - 1 Like   #1
D1N0's Avatar
Pentax-M 100mm F2.8 very soft and distorted
What is wrong with it? I focussed this on a wet window pane.
For original see flickr. It makes some very interesting highlights and bokeh balls with rainbow edges. Maybe I should keep it for that but It doesn't seem the normal behaviour of this lens.
---------- Post added 07-12-18 at 18:38 ----------
Close up of bokeh highlights:
12-07-2018, 09:43 AM   #2
Docrwm's Avatar
  • Make - RICOH IMAGING COMPANY, LTD.
  • X-Resolution - 200 dpi
  • Y-Resolution - 200 dpi
  • Software - Adobe Photoshop Lightroom 5.0 (Windows)
  • Date and Time (Modified) - 2018:12:07 17:14:47
  • ISO Speed - 100
  • Sensitivity Type - Standard Output Sensitivity
  • Standard Output Sensitivity - 100
  • Exif Version - 0230
  • Date and Time (Original) - 2018:12:07 16:57:12
  • Date and Time (Digitized) - 2018:12:07 16:57:12
  • Exposure Bias - -1.3 EV
  • Metering Mode - Center-weighted average
  • Sensing Method - One-chip color area
  • Custom Rendered - Normal
  • Exposure Mode - Manual
  • White Balance - Auto
  • Focal Length (35mm format) - 100 mm
  • Scene Capture Type - Standard
  • Contrast - Normal
  • Saturation - Normal
  • Sharpness - Normal
  • Subject Distance Range - Distant
  • Lens Model - K or M Lens
  • Compression - JPEG (old-style)
  • Thumbnail Offset - 710
  • Thumbnail Length - 14853
  • Displayed Units X - inches
  • Displayed Units Y - inches
  • Photoshop Thumbnail - (Binary data 14853 bytes, use -b option to extract)
  • IPTCDigest - d98826226439db8b99aee83b29c8b9a4
  • Coded Character Set - UTF8
  • Application Record Version - 4
  • Date Created - 2018:12:07
  • Time Created - 16:57:12
  • Digital Creation Date - 2018:12:07
  • Digital Creation Time - 16:57:12
  • Viewing Cond Illuminant - 19.6445 20.3718 16.8089
  • Viewing Cond Surround - 3.92889 4.07439 3.36179
  • Viewing Conditions Illuminant Type - D50
  • Measurement Observer - CIE 1931
  • Measurement Backing - 0 0 0
  • Measurement Geometry - Unknown (0)
  • Measurement Flare - 0.999%
  • Measurement Illuminant - D65
  • XMPToolkit - Adobe XMP Core 5.5-c002 1.148022, 2012/07/15-18:06:45
  • Creator Tool - Adobe Photoshop Lightroom 5.0 (Windows)
  • Metadata Date - 2018:12:07 17:14:47+01:00
  • Lens ID - 1 0
  • Document ID - xmp.did:4c3666d2-b6e9-0b41-b9d7-ff1f3831fcf4
  • Original Document ID - 726A4FCB7CFF95BA6F2DF6F89C92F7D9
  • Instance ID - xmp.iid:4c3666d2-b6e9-0b41-b9d7-ff1f3831fcf4
  • History Action - derived
  • History Parameters - converted from image/dng to image/jpeg, saved to new location
  • History Instance ID - xmp.iid:4c3666d2-b6e9-0b41-b9d7-ff1f3831fcf4
  • History When - 2018:12:07 17:14:47+01:00
  • History Software Agent - Adobe Photoshop Lightroom 5.0 (Windows)
  • History Changed - /
  • Derived From Document ID - 726A4FCB7CFF95BA6F2DF6F89C92F7D9
  • Derived From Original Document ID - 726A4FCB7CFF95BA6F2DF6F89C92F7D9
  • Format - image/jpeg
  • DCTEncode Version - 100
  • APP14 Flags0 - [14]
  • APP14 Flags1 - (none)
  • Color Transform - YCbCr
12-07-2018, 09:52 AM   #3
photoptimist's Avatar
It's probably a loose, missing, or reversed lens element.
12-07-2018, 09:54 AM   #4
D1N0's Avatar
The back element of the lens was described as having some scratches on it, but I think the is more going on. Not typical scratches, more like stress fractures. The lens it self looks like it has hardly ever been used, so maybe the reason for that was it's flaws. The seller pointed out the scratches very well, but also said it was optically in great condition and no balsam separation. This is the photo he took of the back element:
I can't do it better myself without a flash.
Stopped down the lens gets better but the edges remain very unsharp.
12-07-2018, 10:03 AM - 1 Like   #5
QuoteOriginally posted by D1N0 Quote
Those scratches look like tool marks from being disassembled. Methinks whoever did the job flipped one of the elements.
12-07-2018, 10:07 AM - 1 Like   #6
D1N0's Avatar
The back element seems pretty symmetrical, but the one behind it should be convex on the outside...
12-07-2018, 10:11 AM   #7
Definitely agreeing with photoptimist here, it's most likely a reversed element.
12-07-2018, 10:24 AM - 1 Like   #8
Senior Moderator
BigMackCam's Avatar
I agree. I got a very similar result to this when I incorrectly re-assembled a Kaleinar-5N 2.8/100 macro lens after servicing...
12-07-2018, 10:27 AM - 7 Likes   #9
D1N0's Avatar
Maybe somebody tried to clean some fungus the box looked like it had been stored under some pretty damp conditions.
---------- Post added 07-12-18 at 19:58 ----------
Fixed it, it was the element before the rear element that was inverted. Now the lens is sharp. Thank you hive mind
This video showed me how to open it (since I figured it would be pretty similar to the 135, it was.
---------- Post added 07-12-18 at 20:12 ----------
Difference is obvious:
12-07-2018, 01:09 PM   #10
ZombieArmy's Avatar
The crazy bokeh was awesome though.
12-07-2018, 01:28 PM   #11
dbs
Hi D1N0
You have shelves for lenses , I guess my LBA is rather non-existant all my lenses fit in one bag.
Glad you got it working again
Dave
12-07-2018, 04:50 PM   #12
D1N0's Avatar
I actually need more shelves now. They have started to inhabit my desk
balls, bokeh, element, flickr, fungus, k-mount, lens, pentax lens, pentax-m 100mm f2.8, post, profile, rainbow, slr lens
Multiple Distorted Frames Framed edri Monthly Photo Contests 10 02-14-2018 10:03 PM
Nature Very Pretty, Very Yellow, Very Big Flower. Tonytee Post Your Photos! 14 06-12-2016 03:45 AM
Project 52 P52-5-44: Perspective-Distorted-Winners lukulele Weekly Photo Challenges 4 11-25-2013 06:55 PM
Pentax ist D dull and distorted color photos Budgie Visitors' Center 18 10-09-2013 01:19 PM
Very, Very, Very Large Format Camera Available shutterdrone General Talk 22 03-22-2008 10:43 AM
All times are GMT -7. The time now is 06:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
