So was passing by a vintage lens store today, and saw a bargain bin outside (everything $10), had to look through it. Saw this lens, in very good condition cosmetically, very clean glass, looks great, definitely K-mount. Got home, mounted fine on K-1. Took it apart to see what's what, cleaned some of the dust out, and tried to apply some new grease on the helicoid (cleaned off as much as I could the old stuff that was on it). Still quite stiff. Was wondering if anyone has any advice on how to deal with it. Has anyone taken one apart? It's a non auto lens, fully manual, and optical formula seems pretty simple. Should I just take it apart completely? The helicoid is almost fully exposed, just need to take the focus ring and extend the barrel to full length (that's how I cleaned the old grease off). Can i maybe just put few drops of WD-40 on the helicoid and move it around? would that losen up the old grease further?
Thanks
This is the closes I could find to what I have, I couldn't find one exactly like mine -
http://allphotolenses.com/lenses/item/c_696.html
