Originally posted by Roadboat24 This whole thing came about because the discussion was to get the 28-105. But I already have the 24-70 and 70-200. I couldn't see what advantage to now include the 28-105 as I could put the K1 in crop mode and achieve 105 without changing lenses. Anyways, That's what I do..for better or worse. Yep, they are both Tanks, I don't mind.
If I had the 24-70 and the 70-200 as you do, I wouldn't bother getting the 28-105. For the most part the fact that you have your full frame camera with a 24-70 while on full frame is fine. Then you have the 70-200, which I understand in an excellent portrait lens. If you're planning to take mostly portraits at a particular time, I would use the 70-200...you have a very good range of 'portraitable' (to coin an awkward phrase)
focal lengths within that lens...70...to 105 and beyond...all at your zoom hand.
If your doing some general walking around at some event..or just walking around...the 24-70 is your pick. Wide angle to moderate telephoto and everything in between and yes if you want more reach at the top end, just switch to cropped frame and you have 105mm at our disposal.
Nope, I don't see any reason for you to buy a 28-105...with the 24-70 and 70-200. You've got it all in that range and both those lenses are fast F stoppers and quality lenses that cover a wide range of focal length.
