12-12-2018, 01:39 PM   #1
Lord Lucan's Avatar
Lens Cleaning Fluid Question
I need to get some new lens cleaning fluid and saw a recommendation for Zeiss and Elcipse brands. I then found Eclipse being sold on line ..... but hang on, it is not recommended for Sony cameras!
ECLIPSE? Lens & CCD Cleaner (59ml Bottle) | Photographic Solutions | Sensor Cleaning Fluid | Just Ltd
Now I don't have a Sony camera, just Pentax, but nevertheless this is a bit worrying, especially as mentioning Pentax is often forgotten (as we here know). What is special about Sony lenses that they cannot be cleaned with this stuff, and do Pentax lenses share that same characteristic? Is it maybe because of a particular plastic used by Sony, and maybe also by Pentax? Or is it just that someone at Sony has a "thing" against cleaning any lenses with any fluid (some people do, I know).
Can anyone here assure us from experience that Eclipse fluid is OK for Pentax lenses, old and new?
12-12-2018, 01:56 PM - 2 Likes   #2
BigMackCam's Avatar
I believe the issue with Sony isn't its lenses, but rather the sensor or the material covering this - hence why certain sensor gel sticks are designed specifically for Sony cameras.
You should be absolutely fine with Eclipse fluid for Pentax camera sensors - and any lenses, regardless of brand.
I will say, however, that after trying all manner of lens cleaning solutions, my favourite approach - unless you're actually servicing a truly filthy lens and all of its elements - is to simply breathe on it and wipe very gently with a good quality, lint-free, single-use lens paper - or, if you prefer, a good quality lens cleaning cloth (note, you should always blow away any debris - even if it's not visible to your eyes - with a rocket blower first; alternatively, brush it away gently with a soft-bristled make-up brush). I've read occasionally that there may be acids in human breath that aren't ideal for lens cleaning, but personally, I feel that's absolute tosh considering the amount of contaminants floating around in our air. Anyway, this is what I now do for general cleaning. Otherwise, I use Zeiss lens cleaning fluid, or occasionally pre-moistened Zeiss lens wipes.
12-12-2018, 03:17 PM - 1 Like   #3
Lord Lucan's Avatar
That makes sense of it. Thanks BigMackCam.
12-12-2018, 04:04 PM   #4
I will say, however, that after trying all manner of lens cleaning solutions, my favourite approach - unless you're actually servicing a truly filthy lens and all of its elements - is to simply breath on it and wipe very gently with a good quality, lint-free, single-use lens paper - or, if you prefer, a good quality lens cleaning cloth (note, you should always blow away any debris - even if it's not visible to your eyes - with a rocket blower first; alternatively, brush it away gently with a soft-bristled make-up brush). I've read occasionally that there may be acids in human breath that aren't ideal for lens cleaning, but personally, I feel that's absolute tosh considering the amount of contaminants floating around in our air. Anyway, this is what I now do for general cleaning. Otherwise, I use Zeiss lens cleaning fluid, or occasionally pre-moistened Zeiss lens wipes.
Chemically, Eclipse is simply high purity (99% or better) methyl alcohol, according to its MSDS data sheet.
12-12-2018, 04:16 PM   #5
BigMackCam's Avatar
QuoteOriginally posted by baldeagle21b Quote
Good to know - thank you. Do you have a reference for this (e.g. link to the data sheet)?
Given that, my preference stands - even more so, in fact... Breath and a single-use, lint-free lens paper
12-12-2018, 04:18 PM - 1 Like   #6
Otis Memorial Pentaxian
photolady95's Avatar
And this is not a General Photography subject but Lens discussion subject and has been moved there. Thanks for understanding.
12-12-2018, 04:28 PM   #7
FWIW, if anything that won't brush off or looks like it'll need more than a gentle wipe with a micro-fibre cloth and a bit of "huff" I use commercial-grade methylated spirits on a tissue followed by more "huff" and a microfibre cloth ... relatively cheap and readily available. Any residue left from the meths comes right off with the second application of the cloth
12-12-2018, 05:26 PM   #8
Google "Eclipse lens fluid MSDS" and a link to the PDF file should show up.
12-12-2018, 05:47 PM   #9
BigMackCam's Avatar
Thanks again
I'm an amateur when it comes to chemistry, I'm afraid...
I found the following file, but don't know how the information refers to >= 99% methyl alcohol. Is there a way for the layman to determine this based on the information therein?
https://sensorcleaning.com/Eclipse.pdf
12-12-2018, 07:08 PM - 1 Like   #10
That one is a very early version (2001) that doesn't detail the purity. This copy is much newer (2015):
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=2ahUKEwj...Jcits2XA8rCEXt
That's Eclipse's main claim to fame, ultra pure and filtered so it won't leave any residue. That's why they can charge hundreds of dollars a gallon for the stuff (lol).
12-13-2018, 06:46 AM   #11
rogerstg's Avatar
Cool; that makes Eclipse the same as the gas-line antifreeze Heet (yellow bottle, $3 for 12 oz). I'm not surprised because yellow Heet is widely used in alcohol stoves since it burns so cleanly.
12-13-2018, 08:57 AM   #12
QuoteOriginally posted by rogerstg Quote
To be fair to the Eclipse manufacturer, I understand that not only is Eclipse chemically pure but is also filtered to remove any particulate matter that might deposit on surfaces as it evaporates. Substitutes might not have been produced with the same amount of care.
12-13-2018, 01:53 PM   #13
BigMackCam's Avatar
That makes sense. Thanks for the link!
bottle, ccd, fluid, lens, lens cleaning fluid, lenses, pentax, photography, sony
Best fluid for cleaning lens barrels? BigMackCam Pentax SLR Lens Discussion 8 12-28-2017 09:37 AM
Question Question on the fluid layout and opening links in a new tab. bigdavephoto Site Suggestions and Help 5 02-28-2017 05:14 PM
For Sale - Sold: Pentax SF1 with bag, film, cleaning fluid, printer paper, other extras bdery Sold Items 3 12-06-2011 06:08 AM
Cleaning fluid for pentax optics (SMC) jaitas Pentax SLR Lens Discussion 8 10-14-2010 07:12 AM
Eclipse standard or E2 cleaning fluid for k100D and k20D? raider Pentax Camera and Field Accessories 1 12-24-2008 03:47 PM
All times are GMT -7. The time now is 08:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
