12-24-2018, 01:16 PM   #1
akptc's Avatar
One more time: DA* 16-50mm vs. Tamron 17-50mm F2.8 (AF adjustment)
Hi, I just need to confirm what I've gathered through reading older posts and my own experience with the Pentax lens. These two points appear to be true - please kindly comment.
1. Pentax 16-50 is a varifocal lens. As such, it may be impossible to perfectly fine-tune the AF on both the wide and the long ends at the same time. If one end is well-tuned, the other will most likely back/front-focus.
2. Tamron 17-50 is a par-focal lens and can achieve perfect AF at all focal lengths with a single in-camera AF correction.
I have the Pentax 16-50 and have been fighting with the AF tuning for a while now. Tried averaging the error but can never achieve AF quality on both ends to my satisfaction. I am hoping the Tamron lens will free me from this stress.
Looking forward to your advice.
Andy
12-24-2018, 07:19 PM   #2
Closed Account
Hi Andy, and seasons greetings. I don't have the Tamron but I do own the DA* 16-50. Initially I was having similar issues with my copy but found the compromise that suited me and my style of shooting. Waaaayyyy back in 2015 another member was having trouble and I discussed my thoughts with them in the linked thread below. The 16-50 can be a little tricky, but a wonderful lens IMO. Good luck.
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/308662-my-...2-8-sharp.html
12-25-2018, 05:08 AM - 1 Like   #3
Tamron is a better lens if you dont mind losing weather sealing. It is probably the best normal zoom for crop (yes even better than the Sigma one) on all DSLR systems. Even better on Pentax because of ibis
12-25-2018, 06:05 AM - 2 Likes   #4
As far as I know Tamron is varifocal lens too. At least my copy is. If you have zoom lens I think, the best way to adjust AF issues is to adjust it on a longer "side" of the lens, in this particular case 50mm. It is due to DOF which is shallower on 50mm than on 17mm (comparing the same Fstop). That means the DOF on 17mm is deeper than on 50mm so possibility of taking sharp images on 17mm is higher even the focus issues are not properly adjusted.
12-25-2018, 08:55 AM   #5
Tamron isnt varifocal
Quick question on Tamron 17-50mm vs Sigma 17-50mm - PentaxForums.com
That said, no zoom lens is 100% parfocal. When I micro af adjusted mine, I used ~40mm focal length.
12-25-2018, 02:03 PM   #6
I only have the Tamron. I had a problem with it losing contact with any body that Tamron fixed on the 2nd try. At least in the U.S. I'm guessing the body (probably just one) that Tamron uses for calibration is off by 10, which is a fairly huge factor given that my Pentax bodies have only an adjustment range of +/-10, since they calibrated my lens twice now with the same result.
12-25-2018, 04:08 PM   #7
QuoteOriginally posted by nobody Quote
Great recommendation. I would do this too. Mine is actually already tuned at the long end. So I never bothered resetting it.
I have a great copy of the Tamron but just don't like the rendering albeit sharper from DA* in some situations.
12-25-2018, 07:25 PM - 1 Like   #8
akptc's Avatar
QuoteOriginally posted by pjv Quote
[...] my thoughts [...] in the linked thread below. The 16-50 can be a little tricky, but a wonderful lens IMO. Good luck. Is my Pentax 16-50mm f2.8 sharp? - PentaxForums.com
Thank you PJV, I found a decent ruler and plan to take my time adjusting AF at 50mm on the DA tomorrow. Will report on the results. Also thank you everyone who contributed. Btw, I will probably end up also getting the Tamron just to "taste the sharpness".
12-25-2018, 07:39 PM   #9
Closed Account
Good luck, and looking forward to your results.
12-25-2018, 10:53 PM   #10
Try to make sure your focusing screen is in perfect focus by comparing the view through the viewfinder and AF to live view. If the focusing screen is off, you need to shim it somehow to get it to the equivalent distance to the sensor. Once you made sure it's ok, you can proceed with calibration with a ruler.
12-26-2018, 12:50 AM   #11
HippyHippo's Avatar
I own both.
I could never get the Pentax 16-50 to focus properly across the full range of focal lengths either, despite extensive efforts to do so with a calibration tool. It was also unusable at f/2.8. Then the AF died.
The Tamron is noisy and not weather-sealed...but is adequately sharp throughout the range, much better at f2.8 and lighter (plus the AF actually works!).
12-26-2018, 06:31 AM   #12
QuoteOriginally posted by akptc Quote
Andy
I have the 16-50 and use it extensively.
From my experience, the the major problem of get a reasonable af calibration is decentering. And the 16-50 is famous for that.
If you could get yours serviced, try to look for decentering. If you copy are defective, it'll be almost impossible to get a decent calibration.
I get mine somehow adjusted and now are pretty much fine. Reasonable sharpness on 50mm f2,8 and very good upwards.
Also, if that's not the case, doing the calibration on the longer focal lenght is the best way, as it was pointed out already.
Both pictures are f2,8. The first is 50mm and the second 16mm
Hope it helps
PENTAX K-5 II  Photo
PENTAX K-5 II  Photo
12-26-2018, 10:05 PM - 1 Like   #13
akptc's Avatar
The result
After about two hours of fine tuning the AF on the 16-50, I have concluded that this specimen is the spawn of the devil himself and as such needs an exorcism by CRIS.
I tried everything, assuring myself of the angles and distances, used a variety of rulers and other objects and still, just as it looked that I have finally converged on the right fine-tune setting, if I then focused on something a little closer or farther, the lens would again be severely off-focus. I am physically exhausted by this process and have used up my entire curse word vocabulary several times over. This lens is going in for a major surgery. Or the trash can. I do own a large hammer...
Thanks everyone for your advice, I greatly appreciate each and every post.
Edit: Apparently CRIS is not the place for Pentax repairs, I will be sending the lens to Precision Camera
Andy
12-26-2018, 10:11 PM   #14
Closed Account
I have concluded that this specimen is the spawn of the devil himself and as such needs an exorcism by CRSI.
Very sorry to hear this Andy, and also sorry for giving you " false " hope. Please let us know how the EXORCISM goes.
12-26-2018, 10:21 PM   #15
akptc's Avatar
PJV, not at all, I am kind of glad to have suffered through it, I think I can now fine tune any healthy zoom quickly, with my eyes (almost) closed
af, k-mount, lens, pentax, pentax lens, slr lens, tamron, time
K-5 vs MZ-S vs LX vs PZ-1p vs ist*D vs K10D vs K20D vs K-7 vs....... Steelski Pentax K-5 & K-5 II 2 06-28-2017 04:59 PM
Deciding on new Primary Lens [Pentax 16-85 vs Sigma 17-50 vs Tamron 17-50] Marcus_H Pentax SLR Lens Discussion 38 12-31-2016 07:22 PM
Sigma 17-50mm F2.8 vs Tamron 17-50mm and Pentax DA* 16-50mm Adam Pentax SLR Lens Discussion 89 12-28-2014 07:28 PM
Shootout #2 - DA 15 Ltd / Tamron 17-50 @17 / DA* 16-50 @16 / Sigma 10-20 @16 EarlVonTapia Pentax SLR Lens Discussion 4 06-23-2013 10:17 PM
Da 16-45mm f/4.0 ED AL vs Sigma 18-50mm f/2.8 EX DC Macro vs Tamron 17-50mm f/2.8 XR Deni Pentax SLR Lens Discussion 32 01-14-2010 11:13 PM
All times are GMT -7. The time now is 12:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
