12-25-2018, 06:56 PM   #1
Samyang 85mm on K-1 mounting issue
Hello all,
I got the samyang 85mm 1.4 lens for Christmas and I noticed when mounting it. If the lens is set to A I can't get the lens to mount properly. I have to close the aperature some then it will lock in. Then I can change the lens to A and it works fine.
Thanks.
12-25-2018, 07:20 PM   #2
amateur dirt farmer...
pepperberry farm's Avatar
just thinking of all the 'A' lenses that I have and it doesn't matter a whit where the aperture ring is set when mounting the lens - can you post a shot of the lens mount on this Samyang?
12-26-2018, 12:45 AM   #3
There is perhaps an issue with the retracting A contact.
12-27-2018, 11:09 AM   #4
So when the lens is set to f/22 it works fine it's only when set to A. It just gets stopped and cant move further.
85mm, 85mm on k-1, change, k-mount, lens, pentax lens, samyang, samyang 85mm, slr lens
Samyang 85mm f/1.4 or SMC Pentax M 85mm f/2? Wasp Pentax SLR Lens Discussion 77 1 Day Ago 03:42 AM
mitakon 85mm f/1.2 vs a combo of porst 50mm f/1.2, samyang 85mm f/1.4& 8mm f/3.5 funkythiru Pentax SLR Lens Discussion 21 12-07-2017 12:24 AM
Lens Mounting Ring Issue mars76 Pentax K-r 3 04-10-2017 09:55 AM
Takumar 85mm 1.8 vs. Samyang 85mm 1.4 vespats Pentax SLR Lens Discussion 5 09-15-2011 05:26 PM
All times are GMT -7. The time now is 05:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
