12-26-2018, 06:44 PM   #1
Alnjpn's Avatar
Looking for a second 35mm for street
Hi all,
I have been using the plastic DA35 2.4 for street photography. I really like the field of view it gives on my K3, plus it is fast focusing. However, I find the lens difficult to love. The front element is a little exposed and the build is sharp and plasticky. So I am looking for a lens that gives me the same field of view, is fast focusing and lovable at the same time - any ideas? I have used the da40xs which I do really like but it is just a bit too tight. My budget is around 200 dollars second hand. Thanks.
12-26-2018, 07:15 PM - 3 Likes   #2
Kozlok's Avatar
Save up and get an Fa31. You can get a used one with some scratches on it for ~500-600 if you are patient. The Sigma 30’s are worse than the FA for street photography, but I do like the Sigma for posed portraits.
12-26-2018, 07:18 PM - 1 Like   #3
Do you need autofocus?
There are any number of older 28, 31, and 35 mm lenses - many of which perform admirably on the new APS-C cameras. Take a look at the lens review database for the FA, F, A, M and K lenses: Pentax Lenses - Pentax Lens Reviews & Lens Database
Many of these lens come from the "old days" and have a substantial feel and construction!
12-26-2018, 07:25 PM - 1 Like   #4
amateur dirt farmer
pepperberry farm's Avatar
look for a good, used copy of the DA35 Macro Limited - I was in the same spot with my DA35/2.4
12-26-2018, 07:41 PM - 1 Like   #5
UncleVanya's Avatar
FA 35... better build and just nicer than the DA 35 F2.4
12-26-2018, 09:12 PM   #6
brightseal's Avatar
I've been spending way too much time online lately and the pickins' are slim to none, the K1 killed the after market. You can not find even a used 35mm for under $200 except for the M35. All you can do is save your searches and wait it out. Check the marketplace here often, you might get lucky. If you see something, pounce quickly. The next 35 is probably the FA 35 for maybe $250.
Maybe consider an F 24-50 or F 35-70? DA 16-45 ? DA 18-55 ?
Good Luck
Also remember the shopping season is over so you may see something pop up in the coming weeks.
Oh did you see this? for $200: https://www.pentaxforums.com/forums/24-photographic-equipment-sale/380422-sa...tax-d-bg2.html
12-27-2018, 12:45 AM   #7
hcc
hcc's Avatar
QuoteOriginally posted by Kozlok Quote
+1 for the FA31mm f1.8 Ltd. A great lens IMHO. Worth its money and a good longer term investment.
My 5 cents.
12-27-2018, 12:59 AM   #8
bassek's Avatar
I find the 35mm a bit narrow for street photo on crop. How about the 21mm limited? It should fit your budget used.
Zooms are found cheap, but I assume (as they would be obvious) they were out of the question?
Seb
12-27-2018, 04:03 AM   #9
Seeker of Knowledge
aslyfox's Avatar
if you truly want the same exact " field of view " as the 35mm, you are stuck with a 35mm lens
otherwise, might I suggest 28mm
I have a Kiron, one of the companies that provided lenses to Vivitar to market under that brand name:
Kino Precision Japan Kiron 28mm F2 MC P/KA
check the reviews for 28mm variations
some examples can be found in these threads
Kiron Lens Club - PentaxForums.com
DSLR fun with 28mm: Club for any 28mm lens - Page 10 - PentaxForums.com
12-27-2018, 05:54 AM   #10
Docrwm's Avatar
The F35-70 can be had CHEAP and is often called a "stack of primes". It's small and fast AF.
12-27-2018, 11:30 AM   #11
QuoteOriginally posted by Alnjpn Quote
FA 31mm F1.8 Ltd or FA 35mm F2 are stellar lenses-I own both- but too expensive regarding your budget.
You may find a good used 35mm F2.8 in K mount (e.g. Vivitar or Panagor Auto Wide-Angle 35mm f1.9 ; Cosina or Petri or Vivitar VMC 35mm f2.8 Cosinon W MC).
12-27-2018, 01:28 PM   #12
If you're on a limited budget it might make more sense to get a different focal length (say 24mm or 28mm) rather than doubling up on 35mm. Yes the 35mm F2.4 is quite cheap feeling but it's a decent performer and you'll have to spend a fair amount of cash to get a better AF 35mm. If you don't mind AF then you could look at one of the older MF Pentax lenses or even something in M42 (maybe the 37mm MIR-1b, which can be had cheap and is a nice lens).
12-27-2018, 05:39 PM   #13
If you want a different but still excellent 35mm prime, plus 1 in favor of the FA 35mm f/2. Faster for lower light situations than the DA model, and built much better with a metal mount and dedicated hood. It is also full-frame for film shooting or on a K-1.
12-27-2018, 07:30 PM - 1 Like   #14
Alnjpn's Avatar
Thanks everyone for the advice. I am choosing between the FA35 and DA35 2.8macro - both are similarly priced here. The 31 ltd is a nice thought but just out of my price range. I have the da21 which I use occasionally but find it a little wide for my style of shooting. Hopefully one of these 35s will be my New Years present. Thanks again!
12-27-2018, 07:31 PM   #15
Seeker of Knowledge
aslyfox's Avatar
Thanks everyone for the advice. I am choosing between the FA35 and DA35 2.8macro - both are similarly priced here. The DA31 ltd is a nice thought but just out of my price range. I have the da21 which I use occasionally but find it a little wide for my style of shooting. Hopefully one of these 35s will be my New Years present. Thanks again!
good choices
field, k-mount, lens, pentax lens, slr lens, street, view
Thematic Street Photography (No, Not THAT Street Photography) - Share Your Shots of the Roads Sagitta Mini-Challenges, Games, and Photo Stories 3819 25 Minutes Ago 01:47 PM
Old, second hand street market in Japan biz-engineer Pentax SLR Lens Discussion 3 03-20-2015 10:58 PM
Looking for a second body for Weddings sharepointalex Pentax DSLR Discussion 13 03-06-2014 09:54 PM
looking for a second body - suggestions? nobbsie Pentax DSLR Discussion 13 09-28-2009 06:52 AM
Street Photography-Photographing the street photographer? Reportage Photographic Technique 10 03-23-2009 07:41 AM
All times are GMT -7. The time now is 02:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
