Originally posted by pepperberry farm
ah, the much-maligned Porst 55/1.2
victim of so much re-posted, unverified garbage.... if you have one, use it - shoot it day in and day out, get good with it.... then post your shots and a review...
(can you tell I love my copy?)
I hope you're not referring to me
For my own admission my initial judgement of the lens was affected by the choice to trust my eyes (and the phase-based focus confirmation led), focusing through the optical viewfinder.
I believe others have made the same error.
This lens is more difficult to focus than the other two, because of course the focusing is done wide open, not at the working diaphragm... and wide open this lens glows more than the others. So even if the shot is taken stopped down, the result is often marred by mis-focusing.
I'd say that in principle all super-fast fifties should be focused with great care using LiveView (better enlarged!). Though the Porst needs it more than the others.
Under a certain point of view it's even better than the other two, if the goal is to use it creatively. Which means to shoot almost exclusively wide open, making good use of the beautiful glow of the high lights.
I have revised my judgement about this lens after I decided to give it another chance.
I brought the lens with me for a few months, and I'm trying my best to focus correctly in low light conditions.
I had seen some pics posted by @
pepperberry farm, which were clearly sharper than mines.
What was wrong?
I wanted to know if my example was inferior, or there was an entirely different reason.
Maybe your lens is a little better, but I believe that most of the photos I shot with this lens could have been focused more accurately... which in turn could have led to much better sharpness.
Now I have a better understanding of the lens, but I still prefer the Revuenon. IMHO, it has better overall performance.
All the three lenses are a very good choice, for different reasons. If I had to give my score, 1 to 10, I'd give the Porst an 8 1/2, a 9 for the Pentax, and a 9+ for the Revuenon.
The evaluation is very similar, but these lenses are as different as the (same) basic optical design allows.
Cosina, more or less in the same period, decided to release both designs under its brand, one being the Cosina 1:1.2 55mm, and the other the Cosinon-S 1:1.2 55mm. The former a Tomioka design, the latter a Cosina design, siamese twin of the Porst.
If the two lenses were more or less the same, t would have made no sense to sell both.
Regarding the sharpness level stopped down, my example is not bad, I can't say it's lacking sharpness, but I believe that the other two have an edge in this regard, especially the Pentax.
Let's be clear, none of them is a sharpness champion. Even an humble f/2 single-coated can do better. To each its own...
Here is a recent picture, shot with the Porst wide open.
The photo highlights the problem of correctly focusing on the right plane, with subjects that have a certain volume.
The importance of nailing the perfect focus with such minimal DOF is evident in this pic.
The focus is a touch in front of the ear, should have been on the eye. The difference is minimal, but it affects the perception of sharpness.
The background is gorgeous, and becomes an important part of the image.
At f/2 it does not sharpen up that much:
While at medium apertures (in this case, f/5.6 or f/8) it gets a lot sharper:
All the pictures, either shot with the Pentax, the Revuenon or the Porst, have gone through minimal PP.
With some efforts the images could have been much better, but this was not the scope of my posts.
I want to show what the lenses can give, not how good Lightroom is!
