01-05-2019, 09:12 AM   #1
SMC Pentax-FA 28-200mm F3.8-5.6 AL [IF] - broken internal ring
Hi Pentaxians :-)
I've been using my SMC Pentax-FA 28-200mm F3.8-5.6 AL [IF] as a cheap but efficient walk-around lens.
Main drawback is its zoom creep. I use a rubber band to prevent it from extending when I walk, but it looks like it wasn't enough...
In the photo below, the red framed part should stand attached to the green framed edge.
The lens is still usable by holding the front end when it's extended, but I'd like to try to repair it.
I tried sticking it with basic super glue but as you'd expect, it didn't stick anything.
It seems to be some kind of metal alloy. Any idea about how to stick it back ?
Best regards from Rennes, FRANCE.
Alex.
01-05-2019, 09:27 AM - 1 Like   #2
UncleVanya's Avatar
JB Weld is the best readily available adhesive for metal to metal bonding in my opinion. The non-quick version is stronger but that shouldn't matter.
I would caution that superglue can damage plastics and possibly lens coatings with the outgassing vapors. I don't think epoxy will do this but be aware of the potential problem. These are inexpensive lenses easily replaced cheaply so maybe worth trying.
01-05-2019, 10:03 AM   #3
Thanks for this quick and useful answer !
Did you mean this product ? JB Weld Original Cold Formula
01-05-2019, 11:26 AM - 1 Like   #4
UncleVanya's Avatar
Yup. Thats it.
01-06-2019, 12:20 AM   #5
Ordered, thanks!
I'll let you know how things go 🙂
01-06-2019, 07:52 AM - 1 Like   #6
UncleVanya's Avatar
Just be sure to wait the full cure time not just the set time before assembling the lens again.
01-06-2019, 08:28 AM - 1 Like   #7
normhead's Avatar
Let me know if it doesn't work out. I have one I don't use much.
01-14-2019, 01:43 PM   #8
Hi there!
I stuck the part this Sunday. Things went quite well, and I reassembled the lens this evening, seems ok!
Thanks so much for your input, I'll let you know how things evolve as time goes by :-)
Best regards!
28-200mm, 28-200mm f3.8-5.6 af, disassembly, f3.8-5.6, k-mount, lens, pentax lens, pentax-fa, slr lens, smc, smc pentax-fa 28-200mm
SMC Pentax-FA 100mm F2.8 Macro stiff focus ring and slightly dirty internal element? Nayu Pentax SLR Lens Discussion 6 11-06-2016 09:26 AM
For Sale - Sold: Pentax SMC FA 20-35mm f4 AL, SMC FA 24-90mm 3.5-4.5 IF/AL Clarky Sold Items 8 06-08-2010 07:50 AM
For Sale - Sold: Pentax-FA 28-200mm F3.8-5.6 AL [IF] cambridge Sold Items 3 10-20-2009 07:05 PM
All times are GMT -7. The time now is 11:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
