Show Printable Version 8 Likes Search this Thread
01-05-2019, 01:36 PM - 1 Like   #16
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by Pentax Syntax Quote
. . . Hard to tell which he needed; both are available
I asked whether the OP wanted the XS and he posted:
QuoteOriginally posted by mysterick Quote
(aslyfox):
This is an original(?) cap for the SMC 40mm Limitd. It's in two parts: the MH-RC 49mm hood and the screw in cap Very classy (if you have one that is!).
so he has the hood with a 30.5mm hole and needs a screw on cap to close the hole.
___________________
by George, I think you got it:
QuoteOriginally posted by yucatanPentax Quote
01-05-2019, 02:22 PM   #17
shiner's Avatar
The OP was asking about the 40mm Ltd, but nearly everyone responded about the XS
---------- Post added 01-05-19 at 04:26 PM ----------
I think you want this:
Pentax Front Lens Cap for DA 40mm f/2.8 Lens - Black 31493
The original may be best; still available
That's actually a good price! I paid big $$ for the cap for my 20-40 Ltd, had to get it from Japan!
01-05-2019, 02:34 PM   #18
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by shiner Quote
. . . nearly everyone responded about the XS
why not, it is, without a doubt, the " best lens in its class " so it deserves to be discussed a lot
01-05-2019, 03:08 PM   #19
I have the SMC-DA 40mm (not the XS), and I just use a standard 49mm lenscap from an old M50mm. Then I can screw in the lens shade when I need to, but I do not rely on keeping the tiny bit as a lens protector. I also have a SMC-DA Limited 70mm, so I can use the hood from that one on the 40mm (I have not seen significant vignetting, but still experimenting).
01-05-2019, 05:07 PM - 1 Like   #20
I guess I am the oddball here. I really like the screw on cap!1 When shooting I just use the hood so I don’t frequently take it off and on. I put a filter on the inside of the hood if there will be sand, debris blowing or ocean spray.
01-05-2019, 05:21 PM   #21
Seeker of Knowledge
aslyfox's Avatar
. . . I really like the screw on cap!1 When shooting I just use the hood so I don’t frequently take it off and on. I put a filter on the inside of the hood if there will be sand, debris blowing or ocean spray.
I, too, like screw in caps, I have had press on or snap on lens caps fall off when the lens is in my back pack
so I have gotten screw in caps for as many of my lenses as possible
of course, I usually take off the cap when I reach my destination when I reach the location I am taking photos
01-05-2019, 06:04 PM - 1 Like   #22
mysterick's Avatar
I found a used two piece set on eBay in Canada. Satisfied my OCD with a $23.00 purchase including shipping. End of story. Thanks for your inputs/help.
01-05-2019, 06:32 PM   #23
Paul the Sunman's Avatar
I used to use a 30.5mm UV filter screwed to the INSIDE of the hood. So elegant! However, these days I don't bother with UV filters on any of my lenses, after a bad experience with one I was using on the DA 55-300.
01-05-2019, 06:40 PM - 1 Like   #24
I agree. If I lost my 40mm Ltd. cap, this is what I would do.
01-05-2019, 06:59 PM - 2 Likes   #25
monochrome's Avatar
I’ve lost and found my 40 Limited cap several times. As a consequence I have an extra cap and hood set.
01-05-2019, 08:53 PM   #26
Merv-O's Avatar
Looks like "Proper Planning Prevents Poor Performance".....the old 5 P's
01-05-2019, 10:09 PM - 1 Like   #27
shiner's Avatar
I also have two of many things...
01-06-2019, 04:44 AM   #28
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by Merv-O Quote
I know a similar phrase but with one additional P word inserted between " prevents " and " poor "
01-06-2019, 05:46 AM   #29
Merv-O's Avatar
QuoteOriginally posted by aslyfox Quote
Yes indeed....Semper Fi !!!
40mm, 40mm "tiny" screw-in, cap, da, da 40mm, k-mount, lens, ltd, pentax lens, screw-in, slr lens
Wanted - Acquired: snap on or screw on cap for DA 40mm XS lens - 27 mm aslyfox Sold Items 27 08-09-2018 04:31 PM
Monopod: 3/8" adapter screw stuck on the 1/4" screw !! jpzk Pentax Camera and Field Accessories 29 04-22-2012 08:00 PM
Nature Tiny flower, and a tiny bug bluestringer Post Your Photos! 4 04-09-2012 07:29 AM
Macro Tiny Fly Tiny Bud eaglem Post Your Photos! 6 08-05-2011 05:48 PM
Tiny Tiny tiny! rmtagg Post Your Photos! 11 03-24-2008 05:18 AM
All times are GMT -7. The time now is 12:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
