01-10-2019, 07:18 AM   #1
Focal lenght and FOV in specific APS-C designed lens. Need explanation.
Is the FOV of lens specifficaly designed for APS-C camera the same as lens designed for FF? For example is FOV of SMC Pentax-DA* 55mm F1.4 SDM on APS-C the same as HD Pentax-D FA* 50mm F1.4 SDM AW on FF?
01-10-2019, 07:42 AM - 1 Like   #2
UncleVanya's Avatar
Lets pretend both are 50mm. So lets use the DA 50 f1.8 and the fa 50 f1.4.
The fact that It is desined for APSC or ff isn't what matters as far as field of view. The full frame lens will appear narrower in any APSC camera.
A way to think of it is if you have a 13x19 frame and picture and then add an 11x14 Matt directly over the image - the scene you see will look narrower. That's what happens then camera sensor isn't as large as the full frame lens covers so the image is cropoed on all sides. Some crop lenses can cover more than the bare minimum and can shoot respectable shots on a Full frame sensor with roughly the same angle of view that a full frame would have. Other crop lenses barely cover the APSC sensor and wouldn't be able to shoot a wider image But this is due to a lack of image sensor coverage.
---------- Post added 01-10-19 at 09:47 AM ----------
The take away should be the sensor size sets the angle of view for all lenses of a certain focal length. So even a 50mm 645 lens on APSC will give the same width angle of view as an APSC one. The only time this fails is when the lens can't cover the sensor because it is desined for an even smaller sensor.
01-10-2019, 08:18 AM   #3
Seeker of Knowledge
aslyfox's Avatar
I agree with UncleVanya
As I understand it, the focal length of a lens does not change regardless if you use it on a full sensor camera or a ASP-C camera
the FOV of the lens changes only because of the different size of the sensor and thus what part of the image is captured by the image:
" If you take a photo with a smaller sensor and the same lens it will only show a smaller area of the scene. "
Crop Factor Explained
_________________
Full Frame Sensor vs Crop Sensor: Which is Right For You?
_____________________
The Crop Factor Unmasked
Field of View vs Focal Length on various formats
Read more at: The Crop Factor Unmasked - Articles and Tips | PentaxForums.com
01-10-2019, 08:19 AM   #4
photoptimist's Avatar
QuoteOriginally posted by nobody Quote
The short answer is no. The FOV of SMC Pentax-DA* 55mm F1.4 SDM on APS-C will be much narrower than the FOV of the HD Pentax-D FA* 50mm F1.4 SDM AW on FF.
The longer answer depends on three facts:
First, the focal length of a lens is a geometric property of the lens and the lens alone. Focal length is entirely independent of the format of the camera it was designed for or the camera the lens is put on.
Second, the FOV of a particular lens on a particular camera is a function of both the focal length of the lens and the physical size of the sensor or film format size of the camera. For a given focal length, smaller formats have smaller FOVs. For a given format, longer focal lengths have smaller FOVs.
Third, a lens can have a "design FOV" which is the largest angular view that the lens is capable of producing without unacceptable softness and vignetting. This is the size of the image circle projected by the lens. A 50 mm DA lens might have a small image circle that does not cover a full frame sensor.
01-10-2019, 08:20 AM   #5
c.a.m's Avatar
Edit: I was typing at the same time as @photoptimist!
@nobody, the 'field of view' (FOV) can refer to either a dimensional (e.g., feet, meters) or angular (degrees) measurement.
In general, a full frame camera gives a wider FOV than an APS-C format camera, for a given lens focal length.
Here are the horizontal angular fields of view for your cases:
DA* 55mm lens on an APS-C camera: 25 degrees.
D FA* 50mm lens on a FF camera: 40 degrees.
Certain lenses that are designed specifically for APS-C cameras do not provide the wider 'image circle' that is required by a full-frame camera. An example is the DA 15mm Limited lens -- its image circle won't cover the entire sensor on a K-1 camera, so its images show black corners on that camera.
- Craig
01-10-2019, 08:27 AM   #6
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by c.a.m Quote
. . . Certain lenses that are designed specifically for APS-C cameras do not provide the wider 'image circle' that is required by a full-frame camera. An example is the DA 15mm Limited lens -- it won't provide the necessary FOV on a K-1 camera, so its images show heavy vignetting on that camera.
- Craig
this might be of interest:
Full Frame Coverage of DA Lenses: Comprehensive Test
Which DA lenses cover the full 24x36 mm frame?
Read more at: Full Frame Coverage of DA Lenses: Comprehensive Test - Gear Guides | PentaxForums.com
01-10-2019, 09:23 AM   #7
To put it simply: no. 55mm on APS-C gives you a 29.4 degree diagonal FoV, whereas 50mm on full frame gives you a (much wider) 46.8 degrees. Refer to the table below:
As a rule of thumb, if a lens has focal length f on APS-C, the same field of view would be achieved by a lens with focal length 1.5f on full frame (so in this case 55mm on APS-C would be comparable to ~83mm on FF). The format for which the lens was designed does not matter in this calculation.
01-10-2019, 10:38 AM   #8
On one particular lens, I agree. But what if the lens is 50mm BUT is specifically designed for APS-C camera. Will FOV differ in comparison to FF lens on FF camera?
01-10-2019, 12:31 PM   #9
Inherently, no, the FOV would not differ. However, it's possible that the lens would not cover the FF image circle, and thus only be usable in APS-C mode, in which case the FOV would be reduced to whatever it is on APS-C. This is visualized in the third example below:
01-10-2019, 04:20 PM   #10
A 50mm lens designed for APS-C put on a APS-C camera will have the identical FOV of a 50mm lens designed for FF but put on a APS-C camera.
A 50mm lens designed for APS-C put on a APS-C camera will have a smaller FOV than a 50mm lens designed for FF but put on a FF camera.
A 50mm lens designed for APS-C put on a APS-C camera may have a smaller FOV than that same 50mm lens designed for APS-C but put on a FF camera (if the image circle does not cover FF).
01-10-2019, 04:44 PM   #11
swanlefitte's Avatar
The only difference between a lens for ff and apsc is vignetting. The smaller sensor stays inside the vignetting where the vignetting will fall on the larger sensor.
So a lens designed for apsc projects an image too small for a ff sensor. It gives advantages in design such as size.
01-10-2019, 04:55 PM   #12
All good answers, but I like the short answers best. Any 50mm lens will have the same FOV on APS-C DSLR cameras, whether or not they were designed with FF or APS-C in mind. However, since those lenses designed for the smaller APS-C sensor will usually have the circumference of lens elements cut smaller, so the lens design can take advantage of the APS-C format to physically be smaller, this may result in darkening of the outer areas, especially corners, of images if the lens is used on a FF body.
Will FOV differ (if on APS-C cameras) compared to a FF lens on a FF camera? Yes. A 50mm lens on a FF body will have a wider FOV compared to having it on APS-C camera bodies. To have both the same FOV, for example, you need to have a lens of approximately 75mm (or 77mm) on a FF body to equal the FOV of a 50mm lens on APS-C bodies.
01-10-2019, 05:01 PM   #13
QuoteOriginally posted by mikesbike Quote
All good answers, but I like the short answers.
My answer was shorted.
Yet our approach was the same.
01-26-2020, 02:39 PM   #14
Newbie POV
If I understand the initial question as - if a lens is specifically designed for an APS-C camera and it is marked as 50mm - is it actually, internally a 33mm lens designed to give the same FOV as a FF camera lens marked 50mm, that is 46.8 degrees (from the comprehensive table in an earlier reply)
It makes no sense that a manufacturer, say Pentax, markets two physically different lines of lenses, one range being for FF sensors and having focal length markings that 'real photographers' understand as being 'the real 50mm lens' - whereas their APS-C range has an inaccurate marking of 50mm - because everybody in the know, knows that really means 75mm.... but then again,not everybody is in the know...
I would expect that when I walk into Best Buy to buy a camera, for my old mother, and I buy a model with a 'cropped sensor' and it comes with a 50mm prime lens - that when I look through the lens I will see the same FOV as I would looking through a FF model with its 50mm lens...
As a consumer I would have to say that either all of the manufacturers are scamming an uneducated consumer base - or they are actually doing what I suggest above, making a 33mm lens and calling it 50mm because the FOV is the same as real photographers (and old mothers) understand to be what you would normally see through a 50mm lens we all know and love.
I suppose you could refer to lenses by their FOV just as easily as their focal length, it actually makes more sense, I think it makes zero sense to sell a lens as '...its a 50mm lens, but its actually equivalent a 75mm lens, but we didn't say that... because its 50mm'
I don't know the answer but it shouldn't be so difficult to find out if you have two cameras, (an APS-C and a FF) and two 50mm lenses (an APS-C designed one and a FF designed one) - and a fixed tripod - do you have the same FOV?
If not shouldn't somebody complain?
01-26-2020, 03:58 PM   #15
QuoteOriginally posted by wjparker Quote
If someone is experienced enough to know what 50mm on FF is supposed to look like, they should be experienced enough to know that lenses are measured by their optical focal length independent of whether the lens might be mounted on APS-C, FF, 645, 6x6, 6x7, etc. Focal length is a property of the lens and the lens alone.
And if they are an "old mom" who knows nothing about photography, then they would not have expect a 50 mm lens to be "normal." There's no scam involved. In fact some would say that the APS-C user gets "extra mm of reach" for free with crop sensor!
In theory, lens makers could spec and market lenses by FOV, but that doesn't work if the same lens mount supports more than one body format (as is the case Canon, Nikon, Sony, Pentax, etc. as well as for different film backs on medium format cameras.) It really would be a scam to be told the lens had an FOV of X only to discover it doesn't on your camera.
There really is no way around the fact that BOTH the optical focal length AND the format size affect the FOV (and a bunch of other really important photographic performance variables). If lenses and bodies are interchangeable, then photographers must know both numbers to know if the result will be wide angle, normal, or telephoto.
50mm, angle, aps-c, apsc, body, camera, cost, f1.4, ff, format, fov, frame, image, k-mount, lenght and fov, length, lens, lenses, pentax lens, sdm, sensor, slr lens, telephoto, view
How to cheat ibis about focal lenght? pasorro Pentax DSLR Discussion 25 11-21-2018 10:48 AM
Custom input focal lenght for astrotracer irishbeachboy Pentax K-1 & K-1 II 8 04-02-2018 01:59 PM
Setting proper focal lenght with K-1 and manual lenses Sylwester Pentax K-1 & K-1 II 5 06-23-2016 03:46 AM
Macro Macro lens focal length variation and FOV images to compare? JayR Photographic Technique 2 02-04-2015 05:29 PM
manual lens macro focal lenght question Frank Bowler Troubleshooting and Beginner Help 5 12-10-2010 10:23 PM
All times are GMT -7. The time now is 04:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
