10-03-2008, 06:26 PM   #31
ariahspam's Avatar
That's nice. Come back with some images to share and C&C. (Not everything is equipment).
10-03-2008, 08:30 PM   #32
SpecialK's Avatar
Why I don't recommend the fisheye:
1) It might be more wide than you need (the field of view is like 180 to 100 degrees, whereas the 12-24 is from 100 to 60 degrees approx, so you get the idea, a lens having fisheye means the field of view is dramatically different from a normal -called rectilinear- lens).
2) Fisheye lenses cause distortion, while you can fix it a bit in post processing, it can be annoying.
I find tilting straight lines more "annoying" in some case than fisheye distortion.
I've posted this angle-of-view comparison before, but hopefully it will be new to some. I regret not including the fisheye at 10mm, but too late now.
Attachment 19745
Here's the link to the full-size image.
http://i133.photobucket.com/albums/q78/KylePix/Tests/10-17vs12-24.jpg
10-04-2008, 03:02 PM   #33
hahifuheho's Avatar
Interesting comparation, I think I like a little more the pictures taken with the fisheye.
What is C&C?
angle, dollars, japan, k-mount, k200d, kit, lens, mm, pentax lens, reviews, slr lens
All times are GMT -7. The time now is 01:51 PM. | See also: NikonForums.com, part of our network of photo forums!
