Show Printable Version 15 Likes Search this Thread
01-14-2019, 12:25 AM   #1
SunnyG.'s Avatar
Ricoh lens re coating service!
Is there a possibility to convince Ricoh to start lens re-coating service? It's not that Pentax's modern glass require it, maybe they do once in a while. What if there's a possibility we could re coat old, vintage lenses. It's not like they would do it for free. It would be a paid service.
01-14-2019, 12:30 AM - 2 Likes   #2
Sandy Hancock's Avatar
You understand how economies of scale work on production lines, don't you?
It might be cheaper to buy a modern equivalent.
Anyway, old lenses are desirable because of their vintage characteristics. Why mess around with them?
01-14-2019, 12:46 AM - 1 Like   #3
Unmount the lens completely, remove the old coating, do some pre-treatment for the glass to accept the coating, setup the coating chamber, etc.. That's going to be a service as cheap as buying a new car at least, for a consumer camera lens... I'm afraid that the economics won't fit together.
01-14-2019, 01:06 AM   #4
SunnyG.'s Avatar
I agree with you completely. But wouldn't you like to know, how the 8 element 50mm tak would be with a modern smc coating?
---------- Post added 01-14-19 at 01:08 AM ----------
Hmmm true it would be expensive. But not that much. I mean sigma does it. Is it that expensive? If they did, there's a huge market for it.
01-14-2019, 01:31 AM   #5
Zav
Zav's Avatar
I am not aware of Sigma recoating lenses.
As far as I know, it would be a logistical nightmare. On top of the difficulties with the coating itself, there would be issues with the heavy metals used on glass and soldering as well.
01-14-2019, 01:45 AM   #6
Not to mention that re-coating may well change the properties of the elements enough to change the whole optical formula of the lens.
01-14-2019, 02:52 AM   #7
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by SunnyG. Quote
As a collector of lenses (certain types, at least), this would be my biggest concern... Once you start messing with any aspect of a lens, it's no longer original. Put different coating on the 8 element 50mm Tak and it's no longer that lens - it's something different.
In any case, I agree with other replies... This would be an expensive and uneconomical process. Interesting idea, though...
01-14-2019, 04:20 AM   #8
Digitalis's Avatar
Removing coatings from lenses would involve exposing the lens elements to some pretty horrid chemicals, cleaning, re-polishing and then re-applying the coatings. It would be too expensive to even consider.
QuoteOriginally posted by Zav Quote
Nor have I, though they do offer a mount replacement service.
Coatings are uniform, microns thick and multi-layered. I have tested lenses with the same optical formula with different coatings and I have yet to see any lens that exhibited drastic changes in optical characteristics* with newer coatings. However, Image contrast and flare handling is almost** always improved with modern coatings.
* I have seen slight changes though I am hesitant to state this as an absolute fact, as I would need a greater sample size to tell if the differences were caused merely by sample variation.
** unfortunately some lens designs will flare badly no matter what you do, new coatings or not.
01-14-2019, 04:22 AM   #9
I think there are third party companies on the internet who will polish and apply lens coats. I don't think it is cheap and probably wouldn't be worthwhile for most lenses.
01-14-2019, 04:35 AM - 2 Likes   #10
amateur dirt farmer
pepperberry farm's Avatar
didn't we do this already?
Re-coating Takumar bayonet lens! - PentaxForums.com
01-14-2019, 04:39 AM   #11
Coatings are uniform, microns thick and multi-layered. I have tested lenses with the same optical formula with different coatings and I have yet to see any lens that exhibited drastic changes in optical characteristics with newer coatings.
As expected, I stand corrected. That is why I quite deliberately used the word "may" in my comment
01-14-2019, 05:31 AM   #12
Not a Number's Avatar
I've been unable to find an references or links to such a service by Sigma. Please share any information or links that you have in regards to lens coating/recoating service by Sigma.
01-14-2019, 06:56 AM   #13
Digitalis's Avatar
I haven't heard of Sigma doing this either. I think someone has been hitting the Mezcal a bit too hard.
01-14-2019, 07:45 AM   #14
sergysergy's Avatar
The title should have a "?" instead of a "!". I was excited/surprised for a second
01-14-2019, 08:46 AM - 2 Likes   #15
If you're willing to do all the up-front work of disassembling, cleaning, and prepping your lens element, one of these might be able to help you.
Lens Coating Services
Coating Services - Santa Clara, California - ios Optics
Anti-Reflective Coatings
You probably want to contact someone in their customer service, explain to them what you need, and get a quote before you contemplate having any work done. Be aware there could be some issues coating cemented elements as they can outgas in the vacuum chamber used to coat lenses.
change, changes, coatings, flare, formula, issues, k-mount, lens, lenses, pentax lens, pm, possibility, post, re, resistance, ricoh, ricoh lens re, sample, service, slr lens, smc, takumar
Re-coating Takumar bayonet lens! SunnyG. Pentax SLR Lens Discussion 31 12-03-2018 08:02 AM
A hilarious lens service experience. Pentax (Ricoh) is helpful, Precision is doomed! grahame Repairs and Warranty Service 27 11-03-2018 09:09 AM
Ricoh's new Aero Bright II lens coating Tesla Pentax News and Rumors 23 04-17-2015 05:16 AM
Imaging Resource Article on Ricoh Aero Bright II Lens Coating mgvh Pentax SLR Lens Discussion 5 03-25-2015 12:16 AM
"Professional Service" - 645z users can use free Service in GER mazwick Pentax Medium Format 3 09-12-2014 01:52 AM
All times are GMT -7. The time now is 05:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
