On a 35mm film body or a full-frame DSLR, the traditional best FL for portrait use with low perspective distortion at distances best for framing a portrait, have been between 70 and 120mm for a head and shoulders shot or for a head shot. Since with an APS-C body, which will present an image size with the same lens about 1.5 greater than with a FF body, this means a 50mm lens on an APS-C body will present an image size similar to the 77mm Limited on a FF body shot at the same distance, and thus is more suited for portraiture with APS-C than it would be on a FF body.
The 50mm prime lens having an aperture of say f/1.8 will be able to reduce depth of field DOF if set at this wide-open aperture, and thus can blur the background behind the subject more, to make the subject stand out from the background better. The subject will be sharp against a more blurred background. The degree of this can be regulated by setting aperture accordingly. Lenses not having such a wide aperture setting have a reduced capability or choice in this matter. Additionally, a good 50mm lens having a fast aperture is less costly than a lens yielding a similar portrait-size image on a FF camera when shot at the same distance, and having such a wide aperture. Your 50mm f/2 should work fine, although lens quality is another matter. A lens of greater FL at the same distance and aperture also will reduce DOF due the the greater FL.
The DA 70mm f/2.4 would be very fine for this use, being that the image size equivalency would be like 105mm on a FF body, and the latest HD incarnation also has rounded aperture blades for even a smoother blur (bokeh) of the background. Of course, the FA 77mm with yet greater FL and a wider aperture of f/1.8 can blur background yet more, and has excellent bokeh, and being within the shooting distance and FL for good portraiture.
The 100mm lens is getting a bit long for best portrait results with APS-C bodies, except with subjects having a large nose, so the flattening effect could yield a more pleasing result.
