Originally posted by SharkyCA
I think this fits my thinking originally looking to go with a little wider lens like the HD DA 35 and the 45/38 degree field of view adding the Macro as a plus to the lens. . . .
if not complicated enough, when considering the DA 35mm Limited, do you want the HD version or the SMC version
perhaps this might help [ or just confuse the issue more ]:
HD vs. SMC Pentax Limited Primes
Introduction
At Photokina 2012, Pentax announced a brand new lens coating which they named the "HD Coating". This coating is slowly starting to replace the conventional "Super Multi Coating" (SMC) on high-end Pentax glass. According to Pentax, the new HD coating greatly reduces reflectance without making any sacrifices in terms of durability. This kind of coating isn't new to the industry, however: Pentax digital medium format lenses have been treated with a slightly less durable variant called Aero Bright coating ever since their debut, and other manufacturers have been using "nano" coatings on their premium lenses for several years.
The modern SMC coating that DA lenses have been using for about a decade now isn't the same as the SMC coating that Pentax originally launched in the 1970's. In fact, most DA lenses have been said to have a "ghostless" coating, so while we don't expect the difference between SMC and HD coating to be be a game-changer, it should certainly still be easy to observe. . . .
Read more at:
HD vs. SMC Pentax Limited Primes Review - Introduction | PentaxForums.com Reviews
Conclusion
. . . During everyday shooting, you will most likely not be able ot tell the SMC Limiteds apart from the HD Limiteds. So, if you find a bargain on an SMC lens, or if you simply prefer the old lettering style, you shouldn't hold back. On the other hand, if you often shoot in harsh lighting or sunny environments, then you might want to step up to the HD lenses for their improved coating. The SMC lenses are discontinued, so chances are that they will only be available second-hand in 2014 and beyond.
Read more at:
https://www.pentaxforums.com/reviews/hd-pentax-limited-primes/conclusion.html#ixzz5d5P6Mta2
