09-29-2008, 10:44 AM   #1
Sigmoid's Avatar
Zeiss-Jena 500 f5.6 M-42
Has anyone tried this lens on a *ist-DS or newer Pentax DSLR? I assume (!) that the more-or-less standard M42-to-K-mount adapter would be necessary and workable.
I'm not really up on my Zeiss history but I seem to recall hearing that Carl Zeiss Jena's postwar products were inferior to the West German Zeiss items. Truth or jingoism?
Anyway, this lens is on ebay right now at $200 with 5 days to go. I'm inclined to pay up to maybe $400 or $500 for it. Any opinions?
Sig
09-29-2008, 11:35 AM   #2
I have the Carl Zeiss Jena Sonnar 200 mm f/2.8, and it's among my 3 best lenses.
I don't use it all that often, mostly due to it's size, and weight. However it has excellent optics.
I would at least hope that the 500mm f5.6 version does as well.
You will want to use a tripod whenever your using that lens, and try getting someone else to carry it for you
09-29-2008, 12:04 PM   #3
Just1MoreDave's Avatar
Is it really a Zeiss? None of the photos show the Zeiss name.
I would be curious about this lens, item# 150297589221.
09-29-2008, 01:54 PM   #4
mhertel's Avatar
QuoteOriginally posted by Just1MoreDave Quote
Are you blind? It says "Carl Zeiss Jena" right on the front of the lens..
btw, it's F/5.6 - F/8
09-29-2008, 02:23 PM   #5
troyz's Avatar
QuoteOriginally posted by mhertel Quote
Two different lenses here; The OP is referring to a Pentacon fixed focal length lens; the Flee-bay item# 150297589221 is a Zeiss-Jena zoom.
09-29-2008, 02:40 PM   #6
mhertel's Avatar
my bad, I just say the ebay number and looked it up..
09-29-2008, 02:51 PM   #7
I should have edited, I knew that was going to confuse things.
10-01-2008, 02:52 PM   #8
Sigmoid's Avatar
When is a CZJ not a CZJ?
Guys-
Sorry, I'm so confoosed.
The Ebay vendor called the lens, item number 220285825714, a Zeiss Prakticar Pentacon. A member here said it's really something else. Does this mean that it's really made by another company and labeled as CZJ? Or that the vendor is calling it a CZJ but it hain't?
Sig
10-01-2008, 03:18 PM   #9
mhertel's Avatar
It's not a Carl Zeiss Jena lens, it was made by Meyer/Pentacon in Dresden or Goerlitz.
And it's huge and heavy
Construction - 4 elements, 4 groups
Angular field - 5°
Minimum focusing distance - 6m
Diaphragm action - Pre-set
Minimum aperture - f/22
Filter size - 118mm screw-in type
Push-on diameter - 125mm
Weight - 3500g
Barrel length - 395mm
Special features - screw-off lens hood, rotating tripod-base ring
10-01-2008, 06:48 PM   #10
georgweb's Avatar
Hello Sig,
there you go,
Meyer Orestegor / Pentacon / Prakticar 5.6/500
http://forum.manualfocus.org/viewtopic.php?id=5752
Meyer Görlitz have at some point become Pentacon (lens-label-wise). Both of these have never been CZJ. Lens-label-wise it's quite easy: Any CZJ lens either bears the engraving: 'Carl Zeiss Jena' or 'aus Jena' or simply 'Jena'. So you would always find at least the 'Jena' engraving on any given CZJ lens as a guideline. You will not find any 'Jena' engraving on a non-CZJ-lens and vice versa.
From CZJ I would recommend the 2.8/180 Sonnar, the 2.8/200 like little laker suggested, and the Sonnar 4/300 M42-version (not the Prakticar). The latter lens I do not know but see the lens scheme and expect a bigger 180, which seems to be the reference in east german teles. The middle format people rave about the 180 and the 300 Sonnar, which both need a P6 to M42 adapter.
I would not even pay 200 dollars for the lens you are looking for, cause I don't expect anything from it, compared to modern lenses with better coatings and much better correction and above all portability. In this league (read: big and heavy) I'd recommend the Tair-3 photo sniper lens, which is an M42 MC 300/4.5. It is best sharp at 5.6 and should cost you not more than say 60,- US-$. I do not really have a decent tripod for this beast, and can only imagine what a monster tripod and head you would need for this Pentacon lens.
Hope I did not disappoint you too much, but there is always another lens and there's no cure for this anyway :-)
Best, Georg (the other)
Last edited by georgweb; 10-02-2008 at 04:31 AM. Reason: Name paragraph rewritten ('Jena')
10-02-2008, 07:45 AM   #11
Sigmoid's Avatar
Thanks for your input
All:
I appreciate your comments. This is why I joined the forum!
I currently use a Sigma 400mm f5.6 (early, green, non-APO, I believe) usually with a generic 2X Japanese teleconverter, to photograph osprey that nest high on light poles on a football field near my home in Maryland, U.S.A.
Your comments, along with the fact that the Practikar is only a f5.6, have disuaded me from bidding on it.
Big and heavy don't scare me (much) but the cost of modern lenses of equivalent speed/focal length puts them out of the question. For example, the Sigma 500 f4.5 hits the streets close to $5000 US! If I can get an SMC Takumar or PKA for $500 or so, I'd be willing to put up with the length and bulk.
11-15-2009, 07:33 AM   #12
Pentacon 500mm f:5;6
hello !
i have one Pentacon 5,- 500mm to sell...
one 1,4X converter
one Gitzo monopode
k-mount, lens, pentax lens, slr lens, zeiss
Carl Zeiss Jena Pancolar 1.8/50 MC Help winglik Pentax SLR Lens Discussion 6 03-01-2017 06:10 PM
Zeiss Jena 75 1,5 Biotar M42 angelodn Pentax SLR Lens Discussion 32 11-15-2013 08:31 AM
m42 Zeiss Jena lenses solaris Pentax SLR Lens Discussion 42 03-07-2011 04:19 PM
Zeiss Jena FLEKTOGON 35/2,8 platinum Pentax SLR Lens Discussion 4 11-15-2008 12:43 PM
Portrait with Zeiss Jena speedie Post Your Photos! 5 09-16-2006 05:25 PM
All times are GMT -7. The time now is 01:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
