01-18-2019, 01:00 PM   #1
DA 35/2.4 for astro/nightscapes?
Has someone any experience using "plastic-fantastic" wide open for star images? I use for SMC-PENTAX M 28/2.8, which is quite OK, but tried panoramic night shots last summer and realised it gives better results than expected. I tested some of my lenses but was wondering if DA 35/2.4 could do the job being relatively fast, distortion-free and wide?
01-18-2019, 01:24 PM - 1 Like   #2
Sort of. I'm not super serious about astro and have focused more on night landscape stuff, but the 35 2.4 has worked fine for my usage (highlights well controlled, minimal internal reflections from point sources etc.), I have seen some distortion when stitching panoramas which has taken some fiddling about to get edges to mate properly. When I was using it for straight astro stuff I did find it best at about f4 to avoid issues like coma in the corners of the frame.
01-18-2019, 01:31 PM   #3
QuoteOriginally posted by sqrrl Quote
There's no word on coma in the in-depth review on here, but at Lenstip it was regarded as well corrected in that aspect. Is it noticably worse wide open compared to stopped down to f4?
01-18-2019, 01:51 PM - 1 Like   #4
No, it's actually pretty good wide open, it's probably my favorite lens, and it's my go-to for night photography, but stopping it down one stop does improve it - it's really very good for a cheap lens, but it's still a cheap lens. In the very corners I could see coma and a bit of blurring on star points when wide open, for daylight photography I'd say it's negligible and just ignore it, but with bright points of light I personally find it noticeable and distracting.
Personally I'd look at the Samyang/Rokinon 16mm f2 if I were to get more serious about astro (which I'll freely admit I'm not), there seems to be a consensus among astro photographers that it's among the cheapest 'decent' astro lenses.
01-18-2019, 02:07 PM   #5
Thank you! As you see I really use best of budget gear with M28/2.8 and K-r. If I could afford Samyang I would most probably got K-5 instead. Anyway I apreciate the opinion on the nightscape/starscape use of DA 35.
da, k-mount, pentax lens, slr lens
Why are my nightscapes dark all of a sudden? donkey Troubleshooting and Beginner Help 5 09-10-2017 02:58 AM
Which 35mm lens? (DA 35/2.4, FA 35/2, DA 35/2.8 Macro) LincolnR Pentax SLR Lens Discussion 49 07-19-2017 11:03 PM
Night Nightscapes takis63 Post Your Photos! 4 07-11-2016 06:33 AM
Night Airport Nightscapes FruitLooPs Post Your Photos! 2 08-31-2015 08:55 AM
Cityscape Singapore nightscapes vinceloc Post Your Photos! 7 05-30-2010 05:46 PM
All times are GMT -7. The time now is 12:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
