Partly got this wrong/incomplete when I tried to remember tests I did months ago. Here it is, added info in italic text:
I have the same experience with the Kenko 2x on my DA*50-135.
Observations:
1. The converter works well in screw driver mode with my screwdrive-only-lenses, even those slower than f2.8, though in this case with some hunting in dark situations.
It does this on both K20D (has SDM) and *istDS (has not SDM).
2. The converter and the DA*50-135 autofocus with screwdrive on my *istDS and MZ-5 (tough of course in the later case I'm certainly missing the aperture ring
3. But when mounting the Kenko 2x converter and the DA*50-135 on the K20D the autofocus is dead! Not a sound, not a motion, not the smalest vibration. Screwdrive and SDM is both stone dead!
In the viewfinder "MF" is visible despite that AF is on on both body and lens.
4. I have even tried to isolate the SDM contacts with a piece of plastic film in order to try to make the camera/lens believe it is just a screwdrive converter without the SDM contacts, and still it does not work!
However, when doing this, even exposure functions breaks apart. Alternating numbers are flashing for the exposure time and aperture in the viewfinder and "MF" is now flashing, not a constant light as before. This implies that the SDM contacts are somehow involved in transferring information relevant for the exposure and not only providing the SDM engine with power !?
Hypothesis: Despite that contacts on the Kenko 2x look identical to the contacts on the Kenko 1.5x and Tamron 1.4x (that have been reported to work with SDM lenses) they are not SDM contacts, but power zoom contacts, which for some reason works differently.
But it is not a good hypothesis since it does not explain all observations.
Though I never had a power zoom, I understand it as the SDM use identical contacts as the contacts used for the power zoom. Right? But it appears it is not as simple, or? If the SDM/powerzoom contacts on the converter is just going straight through, why doesn't the SDM engage? If it is not, why doesn't the screwdrive engage even when I cover those contacts. Way strange. Anyone able to explain this to me?
I'm not going to buy any other over-priced third part converter now when the Pentax is around the corner, but my Kenko converter is on queue for some surgery... I wanna know what's inside, what's there that is not as it should be, and if there is something I could fix.
Anyone who have taken apart their fine working and over-priced Kenko 1.5x or Tamron 1.4x converter so we can compare what's inside
By the way. I think I have seen converters on ebay claiming to work with SDM lenses which on the photos appear to have the SDM contacts but not the other 7 contacts on the mount. I don't want to try them, since having exposure functions without autofocus is still better than having autofocus with only manual exposure. But if they work with SDM, it could be that there is some combination of the signal in the SDM contacts and the signals in the other contacts that mess things up. Know its a long shot.
Originally posted by kunik Aperture is not the problem in this case. As I stated the two lenses I tried were 16-50 and 50-135 SDM lenses. Both of these lenses are F2.8. The problem is not that it would not lock focus it is that the AF mechanism would not even engage.
The problem, therefore, appears to be that the Kenko MC7 2x is NOT compatible with ANY of the DA* lenses
The Tamron 1.4x has been going on ebay for more than $200 although it sold new for only $130. Now that Pentax has shown their own 1.4x maybe the Tamron's will get cheaper. Still... in the mean time, how could I justify spending that kind of inflated value on used Tamron gear when new Pentax gear is just around the corner
Originally posted by Douglas_of_Sweden I have the same experience with the Kenko 2x on my DA*50-135.
Observations:
3. But when mounting the Kenko 2x converter and the DA*50-135 on the K20D the autofocus is dead! Not a sound, not a motion, not the smalest vibration. Screwdrive and SDM is both stone dead! I have even tried to isolate the SDM contacts with a piece of plastic film in order to try to make the camera/lens believe it is just a screwdrive converter without the SDM contacts, and still it does not work!
