Originally posted by normhead But you still have to buy a 24, 28 and 35 to even close to the same capability, at which point the 20-40 is the cheaper option.
Yes, and unlike the Limited primes, the 20-40 is WR. Since we are talking landscape here, the slower aperture of the 20-40 at the long end compared to 24, 28, 35 and 40 primes isn't going to matter.
@BigMackCam has noted that he found the 20-40 to have a lot of field curvature at the long end, even stopped down:
Why would somebody buy the DFA28-105? - Page 2 - PentaxForums.com (He posted some samples somewhere but I can't find them at the moment.) It might not be obvious in a lot of situations, but something to bear in mind.
Here's one at 40mm wide open (f4). You get the lovely Limited colours.
I use it disproportionately at the wide end, where it's really good (or my copy is anyway). Even wide open at 20mm f2.8 I find mine quite sharp, and I find the bokeh quite pleasant.
It does really well for landscapes at 20mm f8.
Comparable to my DA 12-24, I think, with perhaps slightly stronger colours and the added benefit of HD coatings (no starbursts but better resistance to flare and pf).
Maybe someone who has both can compare, but the look for landscapes seems to me a bit similar to images I've seen from the DA 16-85. Which is to say, very "digital", if you know what I mean. More predictable and reliable than the FA 43, for example, but without its occasional brilliance.
To take up Sandy's point, there does seem to be some variation in the test results and user experience with the 20-40. Perhaps it's like the girl with the curl in the middle of the forehead - when she was good she was very very good, but when she was bad she was horrid. ;-)
