are you sure?
as noted by .at. the descriptions of the two lenses are different, here are more details:
The optical formula is simple:
5 elements in 4 groups, with one low dispersion to keep aberrations in control.
Mitakon CREATOR 135mm f/2.8 Review
________________________
A bright telephoto prime featuring
an updated optical design, the Creator 135mm f/2.8 Mark II Lens from Mitakon Zhongyi is compatible with Pentax K mount full-frame and APS-C-format DSLRs.
One extra-low dispersion element is incorporated within the design, and helps to markedly reduce chromatic aberrations for increased clarity, sharpness, and color accuracy when photographing in strong lighting conditions. The f/2.8 maximum aperture also benefits working in difficult lighting and also affords greater control over depth of field for using selective focus techniques.
six elements, six groups design, and helps to reduce chromatic aberrations for sharper, clearer image quality.
Mitakon Zhongyi Creator 135mm f/2.8 Mark II Lens MTK135M2BKFPK
