A big thank you to BrianR, tryphon4 and photoptimist for the enlightening discussion on the relative effects of tubes vrs diopters with respect to magnification, light and aperture! One of the nicest, most informative discussions I've read on PF!
This is stuff I did not know explicitly, but totally corresponds with the intuitive knowledge of the Raynox I had developed. Meaning that it's bright as hell, but you need to stop down like crazy. I totally did not know that the Raynox reduces the effective aperture. The upside is that you need very low flash power at a given magnification, which helps the flash keep up when shooting focus stacks at 8.3fps... I guess the downside is that if you were using tubes, you might not need to stack at all for some shots. This is super useful to understand! I just might actually try tubes again for some frontal portraits...
Originally posted by BrianR
Doundounba is a master of this combo, if you haven't already trawled his flickr stream go back to his post in this thread. Raynox should probably give him a commission
Haha! Thanks!! Sometimes I dream that they would license some of my images for their publicity and I would at least recoup the (very minimal) cost of the Raynox. On the other hand, of
everything I've purchased in photography equipment, it's definitely the item that has given me the most bang for the buck...
