Sorry - just a quick sanity check!
Mirror lenses are
supposed to be a little soft in the sharpness department, right?
Taking the first attached pic as an example (straight out of the camera): it's a little flat (to be expected for a catadioptric lens), but it's also a little soft, particularly around the edges.
Now, I can explain that by the shallow depth of field (according to online calculators, ~1cm at this distance (~4-5m)), obviously birds are thicker than that, and thus appear slightly blurry - but at the same time, the rest of the bird is till a little soft.
Q1: Is this sort of image quality to be expected under these conditions (moderate sunlight, distance of 4-5m with 600mm f/8 catadioptric lens)?
Q2: If I
should be getting better image quality out of that lens, is it due to user error (for instance, maybe the focal plane
just a
pigeon smidgeon behind the bird, causing the softness), or is it a fault in the lens (Such as fogging/deterioration of a mirror)?
I have noticed that practically all my images are, to lesser or greater extent, at least a
little on the soft side - but again, I've not been able to determine if it's me or whether the lens has a problem, or if it's just an intrinsic property of the lens itself!
