03-02-2019, 10:01 AM   #1
Autofocus adjustment number in exif data.
As the post, where do I find this in the exif data. I threw my DA 50mm 1.8 on last night and for some reason the focus feels off. I was shooting sharp as tacks with it last April and I want to utilise it more. I just feel something has changed with it and want to investigate.
03-02-2019, 11:03 AM   #2
Exiftool should give you that info; tag name is AFAdjustment. Usage for the command line version would be: exiftool FILENAME -AFAdjustment
Hope that helps!
--Steve
03-02-2019, 11:20 AM   #3
pschlute's Avatar
QuoteOriginally posted by Shenloanne Quote
The setting for AF/FA is not just for setting the adjustment but is also for telling the camera what setting to use. So if you made a single lens adjustment "apply one", then make sure your camera has that setting active. If you have the setting at off or "apply all" then your setting won't be applied.
03-02-2019, 12:54 PM   #4
OK so much trial and error later plus 5 is the sweet spot. Might get some photos tmw int Park with it.
03-03-2019, 02:07 AM   #5
I use nomacs image nomic as software for quick review of my fotos in order to delete blurred, out of focus .. before imported them in lightroom. Nomacs shows exifs datas also the af adjustmen.
03-03-2019, 06:47 AM   #6
Maine_Capt's Avatar
This works great for me. http://exif.regex.info/exif.cgi
autofocus adjustment, exif, k-mount, pentax lens, slr lens
Nature Hibiscus -no exif data Cee Cee Post Your Photos! 12 01-10-2020 02:54 PM
Another question from the ignorant (that would be me) about exif data on forum images Skodadriver Troubleshooting and Beginner Help 6 03-16-2018 08:47 AM
O-GPS1 and your EXIF data - When the GPS is on, it strips data from the EXIF? Sagitta Troubleshooting and Beginner Help 17 11-23-2016 02:25 AM
Does EXIF data include ISO or Aperture data? Newtophotos Photographic Technique 7 09-04-2013 12:41 PM
how to check F-stop , shutter speed and ISO data in MJPEG files (using EXIF data?) Foma2 Video and Pentax HDSLRs 0 10-23-2011 12:13 AM
All times are GMT -7. The time now is 03:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
