03-07-2019, 12:13 AM   #1
SunnyG.'s Avatar
Need help urgently! Vivitar 24mm f2!
What is this? Doesn't look like scratches. Is it possible to open this and clean it? I got 4 Vivitar 24mm f2 in New old stock condition for 180$! Please help me out! And how do I open it!
FRD-L02  Photo
03-07-2019, 12:28 AM   #2
Not a Number's Avatar
Are you sure that's not on the outside surface? Could be "cleaning" marks - damage to the coatings from cleaning. Or just a poor cleaning job that will clear up with a proper cleaning.
If it is on the inside, again could be cleaning marks or element separation.
Looks a little beat up for NOS - e.g. marks on bayonet tab and anti-glare finish.
03-07-2019, 12:49 AM   #3
SunnyG.'s Avatar
I tried to clean the back element on the outside. And it's perfectly clean. The marks didn't go. And the reason I said they aren't scratches, is because there doesn't seem to be any abrasions when held over a halogen bulb. I checked again and again over the bulb. But no damage to the glass. I initially thought those are oil cleaning marks. So I posted it here just to be sure. And I need to know how to open this lens. Because I want to clean it.
03-07-2019, 03:51 AM   #4
amateur dirt farmer
pepperberry farm's Avatar
if that was sold as "NOS", I'd send it back for a refund and not be concerned about opening it up...
03-07-2019, 04:43 AM   #5
SunnyG.'s Avatar
QuoteOriginally posted by pepperberry farm Quote
Really? I am kind of, fond of the images it produces. I was hoping to open it and clean it up. :/
03-07-2019, 04:54 AM   #6
Those marks look on the outside to me. try eg acetone.
03-07-2019, 05:57 AM   #7
Docrwm's Avatar
QuoteOriginally posted by marcusBMG Quote
Dont! Use isopropyl alcohol. Far less likely to strip any coatings.
03-07-2019, 06:02 AM   #8
Have you looked around some to see what other used copies go for? Marks on the rear element are apt to have some impact at some point. If you can return it and pick up another for about the same price, it might be the best route.
03-07-2019, 06:03 AM   #9
QuoteOriginally posted by Docrwm Quote
I can assure you all normal coatings are absolutely immune to acetone.
03-07-2019, 06:37 AM   #10
Seeker of Knowledge
aslyfox's Avatar
before attempting to open up the lens, you may want to review this thread:
Cross-head screws - a caution: - PentaxForums.com
03-07-2019, 08:10 AM   #11
SunnyG.'s Avatar
I used normal lens cleaning fluid. You know the standard stuff, that's available online. For like 10$. And used cotton tip ear buds to thoroughly but delicately clean the rear element. But it didn't go. So I thought it's on the inside. Ok I'll try it, if the marks are still there. What should I do?
---------- Post added 03-07-19 at 08:12 AM ----------
Is it as effective as acetone?
---------- Post added 03-07-19 at 08:14 AM ----------
QuoteOriginally posted by clickclick Quote
Actually I saw a few, pretty worn out ones. Same price as mine. But mine is New old stock. I bought a lot of 4 Vivitar 24mm f2 for 180$.
03-07-2019, 08:49 AM   #12
Docrwm's Avatar
QuoteOriginally posted by SunnyG. Quote
It's been a great tool for me with zero problems. Unfortunately, acetone CAN take coatings despite assurances to the contrary. There are forms of nail polish remover that are non-acetone but I find that isopropyl alcohol works well with zero issues. Also, if it doesn't work you can then try (at your own risk) acetone - but if it does then you avoided any potential risk with the acetone.
03-07-2019, 12:45 PM - 1 Like   #13
SharkyCA's Avatar
I would be extremely careful using ACETONE as it will dissolve a lot of plastics Quote from B&H Photo
"Do not use acetone. Acetone is a great cleaner, but, when used on camera lenses, it could have adverse effects on the plastic and paint of the lens barrel, as well as the optical coatings. Again, do not use acetone."
How to Clean Your Lens and Filters | B&H Explora
Personally I have used ACETONE to WELD plastics together!
03-07-2019, 06:55 PM   #14
I've had isopropyl alcohol strip off the coating on a TC before (either a Tokina or Soligor back in the 80's). Alcohol goes nowhere near any of my equipment since then. Alcohol can also damage the finish and lettering on camera and lens bodies as well as the rubber parts.
03-08-2019, 07:23 AM   #15
So you have 4 copies total? You could use one to donate a rear element if needed. I've not worked on this specific Vivitar lens, but I have torn into I think a similar age Series 1 28-105. To get into that lens, I had to start by unscrewing the rear mount. I was basically able to feel my way through by just removing the next piece down as I went deeper and deeper. So, get a nice clean work area where you can spread out and just go at it. I'm going to guess that you're going to find that element held in place by a part that's going to need a lens spanner. Here are some samples:
amazon.com: lens spanner?tag=pentaxforums-20&
Regarding fluids to clean lenses, as already mentioned, stay away from acetone. Most cleaners seem to have alcohol or ammonia in them. You can search for the MSDS sheets and get an idea of what's in them. Here's a search for them for Eclipse:
MSDS Eclipse lens cleaner at DuckDuckGo
Of note, on some of my newer Pentax lenses (believe it was the DFA 15-30), there is actually a card saying not to use cleaners with alcohol.
And this may be of use - from Lens Rentals on what they do:
Lens Rentals | Blog
24mm, alcohol, camera, cleaners, coatings, element, k-mount, lens, lenses, marks, mine, pentax lens, photo, plastics, pm, post, price, rentals, risk, slr lens, vivitar, zero
Urgently need help with firmware update K3 please ! jpzk Troubleshooting and Beginner Help 9 08-12-2015 08:58 PM
Wanted - Acquired: Urgently looking for a DA 12-24mm/f4 in Australia... lovebytes Sold Items 3 09-23-2012 08:00 PM
Pentax F 35-70 lens help urgently needed jjhenders Troubleshooting and Beginner Help 9 07-26-2011 04:50 AM
Urgently Need Technical Advice benjikan Photographic Technique 4 01-15-2008 07:08 PM
All times are GMT -7. The time now is 08:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
