Originally posted by anselesn I just looked at a whole set of pictures taken with a Sony RX 10 IV, and I cannot believe how good they are. They are all photos of a theatre production, so lighting was tricky. And they were taken from the balcony! But the Sony has an 8.8 - 200 mm lens, f 2.4 - 4, so it lets in plenty of light. And despite that small sensor, the pictures look great.
So now I’m trying to figure out if there is a lens that I could put on my K-70, with its much larger sensor, that would allow me to get shots of a similar quality, in a similar situation. I have the 55-300 PLM, but I don’t think that would do it.
I know the Sony costs significantly more than my K-70, but I still didn’t expect to see such quality from a fixed lens camera.
Someone help me stop feeling like I suddenly want to sell my Pentax and all its lenses, please!
There's no doubt you could get top-notch results from your K-70. But even with the cutting-edge capability of the K-70 for higher ISO/low light performance, the DA 55-300mm PLM lens is not designed to address such conditions. But you might need to get closer or crop your photo.
That Sony outfit has advantages and disadvantages. It has a very wide-range zoom capability, oriented for telephoto but with good wide angle also. It would present an image size in the frame similar to 24-600mm on a K-1 FF body, and it has a relatively fast aperture of f/2-4. The lenses made by Zeiss, so quality should be good. A very convenient range, but it is a fixed lens camera. If you should have need for ultra-wide photography you are out of luck. You can always crop a wider FL to get a tele equivalent image, but you cannot expand a 24mm equivalent image to become like an 18mm equivalent image. Whatever is not already in your frame is not there to begin with. There are also downsides to small size sensors, being somewhat limited in DOF control, etc. For more critical photography for resolution and fine detail, capturing scenes more discriminating and revealing than shooting indoor events in low lighting, a small sensor simply cannot match the resolution of your exceptionally fine 24mm APS-C sensor.
The Sony ensemble also costs around $1,700 USD. For the kind of thing you describe, a theater production taken from a balcony, that Sony model is in its most favorable element. I seriously doubt, however, that with its small 1" sensor it could match the low noise capability of your APS-C K-70 with its outstandingly low noise even for APS-C.
To get close to that range and capability for wide to tele with your K-70, you'd need 2 lenses at least. A start would be a Sigma 17-50mm f/2.8 for the wide to short tele- (about 26-77mm equivalent. ) However, if your goal is to shoot theater activity from a balcony, all you really need is the tele range. You'd need something like 60-400mm f/4 (90-600mm equivalent). I don't know of such a lens. Best you could do is the very fine DA* 60-250mm (90-380mm equivalent) and then crop some to get an image equivalent to that FF equivalent of 600mm if you need to go beyond that 380mm equivalent image. With your sensor's superior resolution, you could get fine results even with the crop.
