03-15-2019, 07:33 AM - 1 Like   #16
Lens caps and hoods.
You'll need to buy 77mm caps, and, if you use a lens hood you'll find that because of its much larger size a 77mm hood won't be very effective, if at all, on, say, a 49mm lens.
03-15-2019, 09:23 AM - 2 Likes   #17
photoptimist's Avatar
Advantages:
* one set of filters to buy and carry
* less vignetting on UWA/WA lenses than a stack of smaller filters.
Disadvantages:
* precludes a lens hood (more flare and less contrast in images)
* can block illumination from pop-up and smaller hotshoe flashes
* more wear-and-tear on the lens' filter threads
* looks funny to outsiders (or looks impressive to outsiders)
03-15-2019, 10:14 AM   #18
Otis Memorial Pentaxian
QuoteOriginally posted by BruceBanner Quote
Hmm...What kinda weirdness?
Way huge on a small lens, that kind of weird. The larger glass may also result more stray light and hood use would be a pain.
03-15-2019, 10:17 AM   #19
QuoteOriginally posted by aslyfox Quote
I have had problem with the snap on caps coming off so I get filter stack caps
Interesting! I have never heard them called that. When I was first getting started in photography (late '60s), they were simply screw-on lens caps. A few of my vintage lenses came so equipped.
03-15-2019, 10:20 AM - 2 Likes   #20
Disadvantages:
One might also add cost...77mm filters fetch a premium price.
03-15-2019, 12:38 PM   #21
Seeker of Knowledge
aslyfox's Avatar
there are screw in lens caps as well
the product I use are the metal " lens filter cap stacks " which you are able to separate and put screw in filters in between a female cap and a male cap in order to protect your filters in storage
03-15-2019, 01:34 PM   #22
Ontarian50's Avatar
I've always considered that there is possibly a negative optical effect of using very oversized filters on a smaller lens - but I'll admit I've never done any testing to back up my theories.
However, if you envision your large filter mounted in a large step ring, a lot of the glass is sitting right in front of shiny black metal (most step rings are shiny anodized black). Some light must penetrate the filter and reflect off the black metal and bounce back towards the filter ... and possibly reflect back towards the lens.
Do you really end up with a ghost image of your step ring? Surely a good hood will help, but not on an ultrawide lens, of course.
Again, this effect may be entirely imaginary, or theoretical, and I've never tried it myself, as I usually carry filters close to the size of the lenses I have. But belief in the theoretical or imaginary has never stopped photographers worrying about such things .... especially when filters are involved.
03-16-2019, 12:03 AM   #23
I have the older version of the Sigma 10-20mm, and it takes 77mm filters, while having its own bayonet lens hood. So operationally no dramas at all - I picked up a CPL for $40AUD secondhand and a UV for $25. The lens hood and lens cap can be used as though no filter on the lens.
The only problems are the usual CPL-on-UWA that Bruce mentioned - various colour casts across the image, especially at the wide end and generally when the sky is in the picture.
Should all be fine Bruce. I also have a grad ND4-to-clear (i.e. half colour with a smooth gradation) that helps me to get better control of brightness when the exposure is dominated by a light sky. This often works better than a CPL to avoid washed out highlights as there is no purple in the corners as the CPL causes. The half colour is actually a 72mm bought for the 16-85mm, and one step down in diameter does not vignette enough to matter.
52mm, 77mm, cpl, filters, issue, k-mount, lenses, pentax lens, rings, slr lens, step, thread
OK, OK, I'm posting. fredralphfred Welcomes and Introductions 5 12-18-2012 03:13 PM
Helios 77M-4 MC 50mm F1.8 Have you used this lens? Metalwizards Pentax SLR Lens Discussion 11 11-19-2012 02:53 PM
For Sale - Sold: Helios - 77m-4 lens laert Sold Items 11 05-15-2012 05:53 PM
All times are GMT -7. The time now is 07:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
