Originally posted by Skodadriver
You might like to compliment it with the SMC Pentax-A 70-210mm f4, another good Pentax lens probably available cheaper than the Pentax 35-105 or the Tamron SP 60-300mm (SP23A) ADAPTALL 2. The adaptalls from Tamron enable the lens to be used with PK and M42 camera bodies using a PK or M42 adapter that mounts on the lens.
The only issues with the old manual Tamrons are purple fringing (very obvious on digital in certain circumstances) and maybe fungus.
The only issue with the Pentax 35-105 might be fungus, seems very robust.
If you want to stick with the vintage of the camera, then for a tele the Pentax-M 80-200mm f4.5 is really quite good. I have one and it would probably be tops for film, and mine is well above average on my K-70 (better sharpness and colours than the very recent DA-L 55-200mm).
I also have the Tamron SP 60-300mm, and that is noticeably better optical performance on digital than the M 80-200mm. So if you want lenses that you can use on the KX and also on a 20+Mp digital camera then the Tamron SPs or the Pentax A series would be better (and you can get the PK-A adapter for them). I have a couple of A series lenses (including the 35-70mm f4) and they look perfect on my ME Super, they look like they belong. Anything later, i.e. the F series, the lenses look wrong on the old camera bodies.
I agree with Astro-baby that the best "look" is the similar-age lenses, which were usually very good for film photography (especially the Pentax M, A and the Tamron SP). The Tamrons look like they are third party though, where the Pentax lenses match visually.
Of all my lenses from the 1970s to 1990s, only one has any evidence of balsam separation (the Tamron 35-80mm) and even that one has no problems with the image unless I pixel-peep on macro pictures.
