03-21-2019, 01:50 PM   #1
D FA 70-200mm compatibility with 1.4x L teleconverter
want to know if the rear converter A2XL will work on a k 1 with the DFA*70-200 f2.8 lens. thanks for any info.
03-21-2019, 02:00 PM   #2
I don't believe it will fit since there's an element at the very back of the lens.
03-21-2019, 03:37 PM   #3
thank you, would you know or recomend a converter for the DFA* 70-200 and K1 combo?
03-21-2019, 06:54 PM   #4
UncleVanya's Avatar
Something to try would be the F 1.7 AF converter. It isn't fully AF but it does offer semi Autofocus - you dial in close and then let it finish.
03-21-2019, 07:58 PM   #5
monochrome's Avatar
I’m away from home, but the A 2x-S might work or the K T6-2X (which is not a great TC for IQ). I can try them Saturday.
03-21-2019, 09:16 PM   #6
Sandy Hancock's Avatar
QuoteOriginally posted by retired2007 Quote
thank you, would you know or recommend a converter for the DFA* 70-200 and K1 combo?
A crop camera?
03-21-2019, 09:44 PM   #7
The DA 1.4 AW Rear converter TC should also work, particularly with the K-1 shooting in crop mode. The DFA 70-200 is on the list of compatible lenses for that TC:
HD PENTAX-DA AF REAR CONVERTER 1.4X AW / Converter / AF Lens Adapter / K-mount Lenses / Lenses / Products | RICOH IMAGING
03-22-2019, 04:18 AM   #8
JensE's Avatar
I'm afraid it's the only combination which keeps Shake Reduction working correctly - no other converter out there seems to convert the focal length reported by the lens. I don't own that combo, but there have been several posts about the amount of vignetting, which is to be expected. It wasn't entirely limited to the APS-C image, but also not covering the K-1 sensor completely. The newest, relatively speaking, Kenko 1.5x (I use the Pz-AF 1.5X TELEPLUS SHQ, but with a Sigma HSM OS lens) and Tamron 1.4x converters, which have all the necessary contacts, should work, but will cause the SR to under-compensate.
03-22-2019, 06:11 AM   #9
A crop camera?
no the K1 is full frame
03-22-2019, 06:19 AM   #10
Seeker of Knowledge
aslyfox's Avatar
as noted in the in depth review of the DA 1.4:
" Note that the A1.4X-L rear Converter cannot be used with most lenses including the DA*300mm lens due to the converter's protruding front element. Thus, the DA converter is much more versatile than the older A1.4x-L converter. "
Read more at: Pentax-DA 1.4x AW AF Rear Converter Review - DA 1.4x and A 1.4X-L Compared | PentaxForums.com Reviews
__________________________
this language about the DA 1.4 appears interesting:
" We mounted the converter on a film body and did not notice any particular vignetting in the viewfinder with lenses 20mm or longer. This is not to say that the converter will be usable in practice with a full frame DSLR should Pentax release one, since firmware could prevent its use. "
Read more at: https://www.pentaxforums.com/reviews/pentax-da-14x-aw-af-rear-converter/conc...#ixzz5iuGbH3mJ
has anyone tried the DA 1.4 on the K 1 or K 1 II shooting full frame ?
_______________________________________________________________________
since the OP is from the United States a rental of the DA 1.4 might be one way to test without buying the converter
https://www.pentaxforums.com/forums/137-photographic-industry-professionals/...ml#post4542890
03-22-2019, 06:56 AM   #11
luftfluss's Avatar
What Sandy is saying - oh so pithily - is the DFA 70-200 mounted to an APS-C camera (like the KP) would be somewhat akin to a K-1 + DFA 70-200 + (theoretical) 1.4x teleconverter.
03-22-2019, 07:57 AM   #12
QuoteOriginally posted by aslyfox Quote
Alas there don't seem to be many examples anywhere online of the combo of K-1 + DFA 70-200 + the DA 1.4 TC shooting in either APS-C or FF mode. But there are numerous reports of the DA 1.4 TC performing well in FF mode on K-1 - but the results are very lens dependent..
03-22-2019, 08:03 AM   #13
UncleVanya's Avatar
Like Sandy mentioned putting it on the Kp, K3, K3ii, K70, etc. will get 24mp into the crop zone of the lens which is more than the 16mp in the crop zone you get from the K1 in crop mode - allowing for higher detail when you need reach. It is likely that the DA 1.4x would work both in K1 crop mode and on the crop cameras without limitations but I don't have any direct evidence of this.
---------- Post added 03-22-19 at 11:07 AM ----------
QuoteOriginally posted by JensE Quote
While this is true of the AF TC's the 1.4x-S and 2x-S manual focus converters (A series or not) will not transmit the SR data and allow the body to be set to whatever SR value you want - if manual focus is sufficient.
My past experiments using the 1.4x-S vs. the DA 1.4x lead me to think the 1.4x-S A version is very close to the same performance at least with my FA* 300 f4.5 used on a K-3.
The 1.4x-S should also cover the FF sensor without problems.
03-22-2019, 08:29 AM - 2 Likes   #14
normhead's Avatar
The HD DA 1.4 vignetting is quite manageable and often would be cropped in any case. I'm pretty sure mine used with my 60-250 gives me about 28-30 MP files when cropped to avoid vignetting. So you're still better off using the K-1 and 1.4 rather than the K-3 I usually use, as long as the critter is close enough. Just leave a bit of crop room around your subject. And remember, my K-3 images are also often cropped. It's not like I have a pile of images that are 100% un-cropped. Cropping provides more advantages than just removing vignetting. There's a pretty good chance you'd be doing it in any case.
That's how I'd handle it.
I use the 1.4 with my DA*200 often, but, you'll find 280mm isn't really that long on an FF camera.
03-22-2019, 08:38 AM - 1 Like   #15
UncleVanya's Avatar
I would defer to Norm - he has a lot of experience with this. Norm what about the F 1.7x converter?
1.4x, converters, crop, da, focus, k-mount, lens, pentax lens, slr lens, sr, zone
From Sigma 70-200mm HSM DG to Pentax D-FA 70-200mm Malsi Pentax SLR Lens Discussion 11 12-03-2017 08:15 PM
Anyone tried the Kenko Teleplus DG 1.4X MC4 Teleconverter with the Tamron SP 70-200mm TheGrandPrixKid Pentax Camera and Field Accessories 3 04-16-2016 07:10 AM
For Sale - Sold: Sigma EX 70-200mm f2.8 + 1.4x EX DG Teleconverter Mile High Sold Items 5 02-14-2010 02:32 PM
For Sale - Sold: Tamron 1.4x Pz-AF MC4 Teleconverter & Quantaray 2x Teleconverter DaveInPA Sold Items 15 09-24-2009 06:28 AM
All times are GMT -7. The time now is 11:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
