Originally posted by milapse I'm trying to take an old lens apart to get to it's guts and I'm stumped on one screw holding the mount on... I know 'techinically' the phillips is not the correct screwdriver but mine fit these quite well... Two came off with a little gusto but clean.
Anyone know where to get the real deal 'cross slot' screwdriver set for lens repair??
I can't recall the name offhand, but a decent tool house should be able to figure it out with not too much difficulty. Probably searching a precision tool seller's website will give you the information you need.
I could be wrong, but a jeweler's screwdriver of the appropriate size might be best.
Also, often stubborn screw can be coaxed loose with a gentle whack from a wee hammer on the back of the screwdriver while trying to turn it.
