Originally posted by HawaiianOnline If you do a lot of travelling, it might be better to hold on to that 18-200mm if you don't want to bring your whole kit with you. I have the Sigma 70-200 DG non-Macro version and it's heavy and bulky compared to the 18-200mm. It really depends on what you want to do and what situations you commonly find yourself in. In a studio type situation I'd use my 77mm Limited or even my Sigma 50mm Macro rather than the 70-200 although I have used it for that before. If I had to be able to quickly recompose like at an indoor sports event, I would defintely use the 70-200 for its relative versatility and speed over the compactness, portability and lightness of the 18-200.
Ultimately, you've got to try to decide what you want to do with a lens before you can choose one.
Let's add a little more confusion to the mix, now that we really have his head spinning.
WHile the 28-200 is a broader range, does this really make a travel camera. It is like one of the Electronic Viewfinder cameras with a 10+:1 zoom, but the widest angle is about 35-40 mm equivelent to film.
The 28mm minimum is just too long for an APS-C sensor. When you travel, generally you want wide not long. You do scenics, buildings etc. Even a 16-50mm is pushing it, as a 24mm equivelent to film, I found to be still not quite wide enough, but I could live with it, and if you only take one lens to travel, that would be the one I would take.
Somebody once said, if you try to make something such that one size fits all, it doesn't fit any.
