Originally posted by Docrwm Does this lens look right to you?
I've worked on a couple of dozen lenses over the years, and I noticed the screw heads immediately when I looked at the picture. The two matching screws appear to be square-slot combination heads, definitely not original. I don't see any obvious damage on the mount other than slight scratches at the 12 o'clock position.
It's not necessarily a bad thing to replace mount screws, as long as the replacements are similar. The originals may have been dropped and lost or they might have been seized and required mechanical extraction, which could have damaged the heads. Regardless, the combination square-slot screws are odd replacements, which might suggest sloppy workmanship or inattention to detail. Certainly not elegant.
