04-08-2019, 01:55 PM   #16
Personally I find the 15ltd best for reportage style photography. The edges are often to blurry for my taste regardless of f stop for architecture and landscape. It's beautiful for reportage style portraits and close ups.
I still use it when I shouldn't and swear by the computer every time I get home
04-08-2019, 02:14 PM   #17
pres589's Avatar
Hey house, can you share an example or two of these "reportage" style shots?
04-08-2019, 02:50 PM - 2 Likes   #18
Sandy Hancock's Avatar
Boring as it might be, do some brick wall test shots on tripod at all apertures to check for de-centring. My copy went back to Japan for a service and and it was worth every cent.
Stopped down to f/8.0 and beyond it is fine for architecture and landscapes.
04-08-2019, 03:25 PM   #19
TerryL's Avatar
Ok, Sandy. I'll do that. I'm sure it's going to be fine. It just has a learning curve with it. I will do the brick wall test, though. Thanks for posting.
Terry
---------- Post added 04-08-19 at 03:33 PM ----------
Wow! These pictures are amazing.
Terry
04-09-2019, 02:27 AM   #20
microlight's Avatar
From memory (not at home at the moment) the old K and M manual 28mm lenses have f8 and one of the distance markings in red, to set for hyperfocal distance. Not easy if the lens doesn’t have an aperture ring!
04-09-2019, 09:22 AM   #21
TerryL, I have the same lens and when I received it I wan't very happy with it either. It should be sharp from approximately 3 feet to infinity. I put it on a tripod and used the focus adjustment inside the camera until it focused at infinity. I think it came out to be about a plus 4. Now the lens is incredibly sharp and it still focuses at near distances. It's my new favorite lens.
architecture, brick, cent, da, f/8.0, k-mount, landscapes, method, method for da, pentax lens, service, slr lens, terry, test, wall
What is the best method to use to capture slow moving subjects with a manual lens? Vantage-Point Pentax SLR Lens Discussion 8 01-28-2012 01:34 PM
Best method to assure optimum sharpness from K-5 and Limited lenses? stevelink Photographic Technique 36 08-27-2011 09:08 PM
Adjust date in DNG Raw file, best method? Can it be done in bulk? WiseOx Digital Processing, Software, and Printing 3 07-05-2011 03:51 PM
best method for p.p noise reduction/removal simonr23 Digital Processing, Software, and Printing 6 10-26-2008 02:04 PM
Clean behind focusing screen - best method? ksignorini Pentax DSLR Discussion 18 05-14-2008 10:57 AM
All times are GMT -7. The time now is 10:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
