Originally posted by TerryL Can you recommend a good AF mode to use for my HD DA 15mm f/4? I definitely want to use it around my house when company is over, and holidays.
Use the previous post's advice and read this thread;
What K3 settings for landscape? - PentaxForums.com
Something else to look at is this;
http://www.dofmaster.com/dofjs.html
All Pentax crop bodies have the same size sensor so you can pick K-7 and it'll work the same as your actual camera. I punch 20 feet away and wide open at f4 to try and get a "worst case" going. Hyperfocal focusing distance is calcuated at just over 9 feet away. That's effectively where you set the focusing ring per my earlier instruction.
To put it another way, with the relative speed of this lens, the focal length of the lens, and the effect of a crop sensor on depth of field, you will probably fine just leaving the focusing ring where it is for a lot of the shots you might take with this lens.
