Originally posted by Sandy Hancock
[/end thread]
From everything I've read, there's nothing wrong with the 16-85's bokeh and rendering. Artistic flair (I presume you didn't really mean "flare") is up to the photographer.
For this particular trip, I'd leave them all behind and buy, borrow or steal a 55-300PLM.
I totally agree with Sandy. With these two WR lenses you have a light-weight combination that covers every length from 16mm to 300mm. Both have very fast and very accurate auto-focus, HD coatings and easily added/removed hoods. This is a once-off opportunity, you don't want to miss shots while changing lenses or figuring out which focal length to use. I have lots of lenses and I mostly use them when I want to play around with artistic options or enjoy differing rendering, but when I need to be totally confident that I have the best chance to get great shots with least amount of time/effort, I use the WR zooms at a reasonable ISO setting.
Definitely the compromise with a zoom-only kit comes when you need the polarizer but you also need good shutter speed to counter movement. So maybe take a small light "sacrificial" lens (i.e. not WR) in case you need a fast shutter, I have a 35 f2.4 DA that would do the job, and OP has one I see.
