04-16-2019, 03:33 AM   #16
I've found one in amazing condition on ebay with a case. would total between 80-90 pounds. Is that too much to pay?
04-16-2019, 07:29 AM   #17
MossyRocks's Avatar
I recently replaced my first S-M-C 28mm f/3.5 as it wasn't in the greatest condition when I got it 20 years ago and it only got worse over the years to where it had so much slop in it that I couldn't get it to focus unless the stars aligned. Given that about 4 weeks ago I found one at a local camera store for $70 USD in excellent condition (almost like new old stock condition) with the case and hood with case I would say 80-90 pounds would be on the high side unless it was in exceptional condition.
04-16-2019, 08:30 AM   #18
All of this is true, but I have found even 24 mm is not wide enough in many city environments
This is quite true, but I sought to give a perspective based on both what the OP is thinking about buying AND what I already own and can advise on.
Additionally 28mm SMC Taks are a dime a dozen, in relative terms; reliably finding something wider than that involves problems of expense and availability.
04-16-2019, 03:09 PM   #19
dms
Sounds high. KEH has an SMC 28mm f/3.5 SMC Takumar for $84.00 (US).
04-16-2019, 03:23 PM   #20
luftfluss's Avatar
QuoteOriginally posted by sh4r1f Quote
Not bad, especially if the case is original and in good shape.
If I bought the Tak from KEH that @dms cited, it would cost me the equivalent of 70 pounds, including tax.
04-16-2019, 03:54 PM   #21
WPRESTO's Avatar
Several responses have mentioned the 28mm f3.5, and I'll add my vote for that as a particularly good M42 WA lens. Also, in reverse mount on tube(s) or bellows it is regarded as a very good to excellent ultra-macro lens (= reproduction greater than life-size).
04-17-2019, 01:02 AM   #22
Looks like the lens is just cheaper in the US. If I order it on KEH it costs $50 to ship here to the UK. So in total that comes out roughly to 101 pounds for one without a case.
I should emphasize that this one on ebay will cost £88 and is virtually mint.
04-17-2019, 05:04 AM - 1 Like   #23
I caved! Bought the S-M-C Takumar 28mm f3.5 for £88. Couldn't find it priced anywhere cheaper except the US where shipping cost would have eliminated any savings.
Pentax 28mm F/3.5 SMC Takumar M42 Screw Mount Manual Focus Lens {49} | eBay
Looks like it's in really nice condition though - will update! Thanks for all the advice and discussion - I have learned a lot from some very informative posts.
04-17-2019, 05:50 AM - 1 Like   #24
MossyRocks's Avatar
QuoteOriginally posted by WPRESTO Quote
I've had good luck using it like that. For example here is an image taken with it just reverse mounted giving about a 2:1 macro that I then cropped to show mostly just one microchip. For perspective the chip is 6mm X 4mm.
04-17-2019, 06:21 AM   #25
QuoteOriginally posted by MossyRocks Quote
That's great! Will be messing around with that if I can. In my case of putting this on a Spotmatic F, would I just need a reverse mount to attach to the lens?
04-17-2019, 06:27 AM   #26
WPRESTO's Avatar
Yes. M42 to a filter thread adapter are reasonably easy to obtain. If you cannot find one with the correct filter thread (I think the 28mm f3.5 used a 49mm filter thread that was the Pentax standard back then), then you just need a filter stepping ring, which are even easier to find.
I'll check B&H to see what they have and add a PS to this post.
PS: Yes, B&H has one, about $15 USD.
PPS: Several available on EBAY including one in the UK for about $21 (?USD). On EBAY search for "M42 to 49mm adapter." There were a couple others on offer from the Eurozone.
04-17-2019, 07:47 AM   #27
MossyRocks's Avatar
Yes it is a 49mm filter thread. I've had a few reverse mount adapters over the years and if you can find the real Pentax one you will be pleased with the quality. Better fit and smoother operation. Used they can be found for around $10-$20 and there isn't much demand at the moment for them.
04-17-2019, 09:08 AM   #28
I really like my 28mm f3.5, so good choice
If you are stricken with LBA, as so many of us are, I'll also endorse the 35mm f2.0. The extra speed is nice, but itís still sharp stopped down.
Have fun!
-Eric
28mm, angle, k-mount, length, lens, lenses, m42, m42 wide angle, mf, mm, pentax lens, slr lens, smc, takumar, version
Help! Advice on Super Wide Angle Lens for K-30 halera Welcomes and Introductions 15 09-26-2018 02:25 AM
Advice on wide angle lens clickity_click Pentax SLR Lens Discussion 31 04-26-2018 11:23 PM
Help / advice for a wide-angle lens mbukal Pentax SLR Lens Discussion 6 12-23-2017 12:01 PM
Get wide angle lens from an extreme angle lens jorgegetafe Pentax SLR Lens Discussion 7 10-08-2015 12:53 AM
First post: looking for wide angle advice and more rparmar Pentax SLR Lens Discussion 16 01-27-2008 07:27 AM
All times are GMT -7. The time now is 06:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
