I have recently purchased two M42 lenses. The 135mm F3.5 Super Takomar and the 200mm F4 Super Takomar. I also bought an M42 to K-mount adaptor, and just wanted to ask are these safe to use with big heavy lenses? The one I bought is not as wide on the camera lens mount as a normal lens - you can still see the red dot and the screws holding the mount on.
