Originally posted by pschlute
That era of lens does have a reputation for not having the most reliable AF motors (it was new tech at the time)
Having said that i had three lenses of that type of AF motor and none of them ever failed. My 16-50 did however require "waking up". So my advice is don't leave it sitting in your camera bag for months on end, and when you go to use it start by manually turning the focus ring to both extremes and make the camera AF work to focus to the other extreme. Then the AF should be fine.
Thank you, Peter. I'll do that. I hope that works. It's a beautiful lens, and I really like it.
---------- Post added 04-25-19 at 03:30 PM ----------
Originally posted by nosliwmit
My DA*300 is currently on the fritz with similar symptoms. I brought it to the local authorized repair center and they advised the motor needs replacement. I collected the lens so I could use it during my vacation but it'll go back to them for repair as soon as I get home. I'm missing lots of shots but still getting enough to justify bringing it. It's hard to nail manual focus...
That's a shame. I had no idea that these two DA lenses had that issue.
---------- Post added 04-25-19 at 03:35 PM ----------
Originally posted by derekkite
When that happens is the viewfinder showing f--?
In any case clean the contacts on the lens and the camera body.
I'll check that, tomorrow. I'll definitely clean the contacts. The camera is new, and the lens looks new, so I wouldn't have thought to clean the contacts. Thank you.
---------- Post added 04-25-19 at 03:51 PM ----------
Peter,
What problem does letting it sit in it's pouch and in my bag cause? Does this sound like my motor is going bad?
