Been reading a lot about peoples experiences with the DA* 16-50mm.
A lot of good.. a few bad... a few nightmares.
It just got me curious, I've been putting it off considering this lens.
I have a Tamron 28-75mm that I am very happy with.
However I've had this nagging issue with the focal length though... The Tamron is the widest lens I own besides the zenitar 16mm FE. Although a excellent lens its just not convenient to use as a regular wide angle on APS-C ... not just that its manual but its an fisheye. Although easy to correct with PT lens just adds some hassle to the workflow when shooting wide often.
For some reason the Sigma 18-50mm/ Tamron 17-50mm just didn't appeal to me at all. Not sure why...
The QC issues has been the breaker for me until now. Being in Australia.. the local prices are almost always much higher than BH/Adorama by a considerable margin.
With this lens having QC issues I wanted to try it and have a convenient return/fix option. So that means buying local.... which has been poor value until recently.
Dollar has dropped considerably against the $US and a couple of local retailers selling at $900. Shipping and rate conversion adds up to be a similar price and even better as the dollar drops further.
So I thought to myself I'll go down to the store try it out... if it is not a good copy.... I can return or refund it.
Took a risk on a lens with a early serial... as the later ones in the store were visibly worse.
First thing I did.. do the Brick wall test... or Concrete wall test.
OK no decentering issues... Phewww
Then I went to take photos..
To sum up my experience so far with this lens..... " WOW "
I am blown away by how this lens renders... colour, contrast, sharpness.....
Its not that my Tamron cannot produce images that are similar.. its just that it takes work in PP to get it to that level that comes straight out of the camera with the DA*
Just in camera LCD... I could see a visible difference to my other lenses.
On my K10D I expected FF/BF but nope... spot on.
Ok the AF is silent but no faster than screw drive.
AF seems to hunt much less in low light...no it won't focus on a blank wall in dim light but it just works with the right technique.
Vignetting and Sharpness visibly improves when stopped down.
So here are a few photos... Absolutely no PP done. Raw straight to jpeg with Lightroom.
43mm f2.8 ISO100
45mm f2.8 ISO100
100% crop
Same Flower same 100% crop at f5.6
50mm f11 ISO100
39mm f11 ISO100
16mm f11 ISO100
So my trusty Tamron.. is off the market soon...
I bet many people have been put off by the QC problems.... I guess in my case my luck held.. and gotten a winner.
Cheers
