05-23-2019, 10:18 AM - 1 Like   #16
bdery's Avatar
QuoteOriginally posted by Ropuchy Quote
If the element is two parts, is it only counted as a single element because it forms a biconvex element?
If it's the same material, but simply manufactured in two parts then glued together, from an optical point of view it's one element. If it was me, I'd draw it like on your image. If it was a doublet (a group made of two types of glass sharing an interface) I'd draw the two elements separately.
05-23-2019, 12:57 PM   #17
Alright, thanks for clarifying!
05-23-2019, 03:36 PM - 1 Like   #18
I've seen some lens designs where there's a section of "tubing" with a lens element tacked on each end. That's another possibility for that circled "element" - could be a couple of air spaced elements.
There are a lot of good introductory lens design books available. Check Amazon and search for "lens design", "optical lenses", and "amateur lens making" (Google also). Most lens design falls under physics, so you might check your public library if it's a large one, in the physics section. Wikipedia is another source (see below), and companies that make lenses like Edmunds.
https://en.wikipedia.org/wiki/Optical_lens_design
https://en.wikipedia.org/wiki/Photographic_lens_design
https://www.edmundoptics.com/resources/application-notes/optics/understandin...ens-geometries
https://www.sciencedirect.com/book/9780123743015/lens-design-fundamentals
05-24-2019, 04:48 AM - 1 Like   #19
bdery's Avatar
QuoteOriginally posted by Bob 256 Quote
In that case, if it was me I'd definitely draw the elements as separate
Learning about optical design in broad terms can be done with some success via wikipedia et al. If someone wants to go deeper, there are some introductory physics books, however they all require some ease with maths. The book "Optics" by Hecht is far from the best, but it's a good one for introductions, with minimal maths and a lot of text.
05-24-2019, 08:56 AM - 1 Like   #20
In that case, if it was me I'd definitely draw the elements as separate .
Totally agree, but some lensmakers (Pentax) take shortcuts or sometimes don't want to give away all the secrets. I believe, the lens I referred to showed a similar abbreviated "lens element" on the box it came in. Not a full-blown lens diagram, but good enough for the sales department
05-24-2019, 11:18 AM   #21
Optical lens design - Wikipedia
https://en.wikipedia.org/wiki/Photographic_lens_designhttp://
https://www.edmundoptics.com/resources/application-notes/optics/understandin...etries/http://
Lens Design Fundamentals | ScienceDirect
Thanks for the links! I'll look into them when I've got some time, the Edmunds one looks interesting.
Also, it looks like 'http://' was added onto the ends of the two middle links, so they won't work correctly when you click on them.
---------- Post added 05-24-19 at 11:22 AM ----------
I actually like maths, just not the stuff they teach in school unfortunately. Do you know of any more technical and to-the-point sorts of books with less reading, or would 'Optics' by Hecht still be a good place to start?
05-25-2019, 12:53 PM - 1 Like   #22
Also, it looks like 'http://' was added onto the ends of the two middle links, so they won't work correctly when you click on them.[COLOR="Silver"]
That's really strange - I fixed those in my original posting so they should work now. Not sure how that happened.
05-27-2019, 05:08 AM - 1 Like   #23
bdery's Avatar
Depends on your math level... Liking math and having completed college-level math classes are two different things. If you want to understand the math underlying the physics, you need to be comfortable with differential equations, solving special functions like Bessel functions (that one is more for fiber optics, but still), using matrices, calculus, etc. Not saying you can't, I really have no idea, but I do know that for a lot of people, what I just wrote is gibberish.
Hecht strikes a good balance. There's an older book, probably called "optics" also, by Mueller. fcuses on matrices a lot (Jones matrices, in fact) so might be easier for some. Introduction to optical design is pretty good, but quite technical, I wouldn't use it as a starting point. There's also the user guide to the Oslo optical design software, it's VERY technical but that user guide is in fact an optical design textbook. A college-level introduction to optics might be "Field and wave electromagnetic" by Cheng, quite good, gives you what you need to know to start learning bout optical design, but of course quite a lot of math.
05-27-2019, 06:23 PM   #24
No worries, I was still able to get them to work. Thanks for fixing them!
---------- Post added 05-27-19 at 06:29 PM ----------
Well, I haven't gone to college yet, so that doesn't bode well.
I'll have to look at your suggestions and see what suits me. Thank you for all the input and suggestions!
05-28-2019, 12:53 PM - 1 Like   #25
Most lens work deals with trigonometry so hope you picked that up somewhere along the way. You'll see a lot of sines, cosines, and tangents popping up in formulas that describe how lenses bend light. Also, there are a number of programs that deal with lens design which do a lot of the number crunching work, and you might be interested in getting something simple there to help you see what's going on (they show light paths on-screen). I think there are a few on-line sites that are interactive that way but I can't remember where I came across them.
05-28-2019, 02:59 PM   #26
Yep, at least I know how to do trigonometry.
I'll look into the lens design programs, and see if I can find a site similar to what you describe. Thanks!
05-28-2019, 07:56 PM   #27
Here's one site I found that's a lot of fun. You can set up simple optical systems and see how they affect light rays while you make adjustments to the various parameters.
https://ricktu288.github.io/ray-optics/simulator/
It fairly intuitive to use and is better than buying expensive software until you get to that really serious point.
05-28-2019, 08:17 PM   #28
Ray Optics Simulation
Thank you for tracking that down for me!
I'll mess around with it a bit, maybe try to recreate some of my lenses.
axis, books, color, colors, design, diagram, diagrams, element, elements, focus, glass, introduction, k-mount, lens, lens design diagrams, lenses, light, name, optical design, pentax lens, post, questions about lens, shape, slr lens, type, wikipedia
Block diagrams of every 645 A series lens Fat Albert Pentax Medium Format 13 02-25-2022 05:10 PM
Super Takumar 1.4/50mm 8-Element "killer" vs 7-Element Sample Comparison Sliver-Surfer Pentax SLR Lens Discussion 10 10-23-2018 03:11 PM
smc DA lens diagrams olepap Pentax SLR Lens Discussion 5 06-07-2016 12:24 AM
FA Limited lens series won the 2010 Good Design Long Life Design Award Patriot Pentax SLR Lens Discussion 26 11-29-2010 06:16 AM
OK...another does this make sense new Pentax person gear list...with diagrams!! :) brecklundin Troubleshooting and Beginner Help 11 06-23-2009 12:46 AM
All times are GMT -7. The time now is 05:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
