Originally posted by Gbhati01 I spent a couple of days experimenting with the 43 vs. 55 focal lengths on my 16-85. 55 seems too tight for indoor use, especially as my kid grows up and starts sitting upright, it would be impossible to use 55 for a waist up shot. So 43 appears to be a better focal length or maybe even 35 or 31. Thanks bdery for highlighting this.
Now 31 ltd is quite expensive
I've got the K-S2 as well and when I got myself a (barely) used ( Sigma 30/1.4 (not the Art, but the older and much cheaper EX DC) I found that I really liked the focal length for indoor use. Focussing is a bit tricky at 1.4, but at 2.0 my keeper rate was much higher (perhaps some focus finetuning needed). I haven't got the DA35 myself, so I can't compare those, but if you're open for third party lenses, you could give this one a try?
If I should ever go full frame, the 43 will be one of my first new lenses after the body.
Quote: Surprisingly in the used market, 43 mm and 55 mm are roughly equally priced. This means that 43 mm commands a premium over 55 - may the fear of SDM failure?
I think there are two more factors at play: the 43 is a limited vs. the 55 "only" a * lens, and the 43 is officially a full frame (FA) lens, while the 55, even if very usable on full frame, is a crop (DA) lens.
